Results 1 to 15 of 15
Thread: VST Fuel Lines
    Aug 2005
    West Allis,Wisconsin
    VST Fuel Lines
    Is there a substitute fuel lines that can be used instead of expensive ready made Mercury lines?
    Looks like 5/16 one is straight and the other is molded. I have the earlier version VST.
    Have fuel seepage at ear clamp at throttle body end, looks like clamp got squeezed to tight and cut through the hose.
    Just be careful if you decide to use a straight hose and make the sweep/bend because I have seen them kink after fuel was run in them.
    I know it sucks what they charge for them.
    EFI kevlar reinforced fuel line, a stainless steel spring inside to keep it from collapsing. EFI hose clamps to secure.
    Aug 2005
    Thanks for the info. Where do u get the Kevlar hose and spring at? Wonder if Pro Marine makes a replacement hose for it??
    I get my fuel line and clamps at napa. My store has the springs also. Same idea as a cars suction side radiator hose, spring inside prevents collapse of the hose. I believe all the formed hoses are merc proprietary parts. Some of the bent hoses with bad ends can be trimmed a little and reinstalled. If you don't mind a loop in a longer hose that will work also. Not very professional looking tho...
  6. Likes KIRCHNER liked this post
    Aug 2005
    Thanks for the info., same principal as the rad. hose. I think I may be able to trim a tad off and use FI clamps. I will check Napa by me.
    Do u know if all 3 hoses come in the Merc kit?
    Boats . net has good parts breakdown diagrams. I think they are sold each...Look your engine up and see.
    Aug 2005
    Thanks guys!
  10. #9
    Feb 2013
    mt holly,nc
    i found this on an Ebay search for formed fuel lines. Made by/for Big Dog Cycles (hi-press. EFI) p#100-000131-00
    Trimmed it up, fit perfect!
  11. Thanks KIRCHNER thanked for this post
    Likes tux974 liked this post
    I have bought and used Ebay# 163179104535
    Feb 2011
    HUDSON, FLORIDA
    I GOOGLED 5/16 Formed fuel hose, i shows a formed hose with about 3 or 4 bends a45.a90.a135 u cut to suite about 15$ my top 2 vst lines are kinked, 1 really bad. several suppliers show same item. also has a 180. they call it a swan hose, rated for 75 psi 5/16
  14. #12
    Quote Originally Posted by KIRCHNER View Post
    Exactly! cut/trim to as need it, I get the 2 needed hoses for $20. Taking a chance on a kink with fuel delivery is not a good thing.
    I have actually swap the brass fitting on the plenum that attaches to rail tubes that use 2-90*. Got away from that "S" hose.
    Crazy Mercury's hose kit list for $100 for 2- 4" hose and 4 clamps, insane.
  15. #13
    Aug 2005
    U got that right! Going to us FI clamps on new hose so it will removable and reusable later. Ear clamps cut into hose to much, every time u put a new clamp on the line cuts in a little more each time if u have to remove it. Want 2 change the reeds right now. Thanks
  16. #14
    can you say oetiker clamp
  17. #15
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by tux974 View Post
    talked with jsre about kinks he suggested std clamp over kink tighten slightly, seemed to work. that snake hose is way 2 go.
  18. Likes XstreamVking liked this post
  1. Fuel lines
    By PaulCXB2002 in forum Technical Discussion
    Last Post: 08-25-2017, 10:03 PM
  2. Best tubing for bleed lines/small fuel lines 2.4 MERC
    By rujr in forum Technical Discussion
    Last Post: 07-10-2013, 10:26 AM
  3. fuel lines
    By speedinmyblood in forum Technical Discussion
    Last Post: 05-20-2010, 03:08 PM
  4. Mercury Tech: Fuel lines
    By CALVIN in forum Technical Discussion
    Last Post: 03-15-2010, 12:15 PM
  5. Mercury Tech: 2.4 BP fuel lines
    By ozziffied in forum Technical Discussion
    Last Post: 02-27-2009, 12:13 AM
