Results 1 to 14 of 14
    Cooper City, Fl
    gearcase identity
    Can anyone identify this old gearcase? My old OMC friend found it in a tool box belonging to his friend that passed away.
    I was cleaning out a old tool chest and found this G/C Pinched between the Drawers. Would you happen to know what make is it and what engines did it attach too? any info would help. . There is a Stamped mark , looks like a letter F . The vertical Driveshaft has 6 splines. Prop shaft diameter is .580 . Bullet diameter is 2".225. The length is 8-1/4 " With 2 to 1 gears. The distance between the mounting stud's is 3 5/16" or 85 mm . I Think it was set aside for a desk lamp conversion , but if some one needs this for a restoration project , I would it go there. Cheers Patrick Eves
ID:	454108   Click image for larger version.
ID:	454109   Click image for larger version.
  2. Likes FMP liked this post
    Its an old OMC case, probably a Johnson from the mid-late 30's Possibly an aftermarket case, but they usually had some id on them somewhere. The time for collecting 1930's stuff, even race stuff, is long gone.
    Someone on the AOMC Facebook page would give it a new home
    Cooper City, Fl
    thank you Sam..
    Dec 2001
    speedy 4........
    Dec 2001
    E Bay 500 $ resvr.....
    Cooper City, Fl
    Dave, you have a link? I can't find it.
    Butch
    Dec 2001
    no link.... just my oppion as to it's value....
  9. #8
    Le Roy, NY
    Johnson A class lower unit
    The 30's B, C class Johnson racers were 2 cylinder opposed motors and had 3/4" propshafts. In 1930 Johnson came out with a 2 cylinder alternate firing twin fishing motor and a race version for the A class. I'm not sure what the prop shaft size was but this lower, I'm sure is from an A class Johnson. I have attached a pic of one of the motors that I used to have. Mine had an aftermarket unit. The above unit appears to be a Johnson unit with the skeg removed.
  13. Thanks lilabner thanked for this post
    Likes lilabner, Mark75H liked this post
  14. #12
    Cooper City, Fl
    Quote Originally Posted by Don Saulsbury View Post
    Thanks very much Don..
    Butch Stokes for Pat Eves
  15. #13
    Dec 2001
    that was my ...Firsts.... motor......w/ out the racing lower unit......still have d/S ......WENT TO MK 20 FROM THERE....GOT SOME BIG 4 LOWERES.....
  1. Identity fraud....
    By flabum1017 in forum Politics, Related News, Religion and Hot Topics
    Last Post: 02-25-2019, 09:09 AM
  2. Mercury Tech: Identity Crisis....
    By MooreRacing in forum Technical Discussion
    Last Post: 06-13-2014, 04:24 PM
  3. Carb identity !!!
    By crazy cajun 2 in forum Technical Discussion
    Last Post: 02-21-2008, 05:05 PM
  4. in-line 6 identity
    By 59powercat1400 in forum General Boating Discussion
    Last Post: 11-02-2006, 01:05 AM
  5. Prop Identity
    By waterrocket in forum General Boating Discussion
    Last Post: 06-11-2004, 03:44 AM
Diamond Marine
