Results 1 to 7 of 7
    Dec 2019
    Denmark
    Autolube disconnect on 98 merc 200 xri efi
    Hi g&gs any body know og i should remove the Oil pump shaft when the autolube is disconnected.? Regards from Denmark 🙏
    Baton Rouge, La
    Most usually do. I think you also need to plug the fitting into the block.
    Welcome !! Someone more technical will answer shortly I'm sure. Mike
    Cheaters never Win !!!
  3. Likes KNG liked this post
    Ft. Lauderdale, Fl
    Quote Originally Posted by KNG View Post
    Mercury makes a kit for removing the pump: https://www.ebay.com/itm/NIB-OEM-Mer...-/291483323585
    Dec 2019
    Denmark
    Thx Guys =D Just orderet a kit. looking forward to summer trying my new toy
    Baton Rouge, La
    Post some pics of your project. I would imagine there aren't many fast boats in Denmark
    Ft. Lauderdale, Fl
    with the kit, you will remove the pump, the remove the shaft behind the pump..... just so you know......
    The shaft has a helix on the end at the crank shaft.... been a while since I did one, but if you rotate the engine (don't remember which direction), it will walk out some then you can pull it out with needle nose pliers..
  8. Likes tunnelmike liked this post
    Dec 2019
    Denmark
    Im going to make another tread with pictures headline will Be Mustang Waverider The wasp 200 XRI From Denmark
  10. Likes tunnelmike liked this post
  1. Quick Disconnect
    By pbxcomm in forum Technical Discussion
    Last Post: 01-19-2018, 02:39 PM
  2. 96 EFI 250 Merc, to disconnect oil injection or not ??
    By davepnola in forum Technical Discussion
    Last Post: 05-09-2008, 06:27 AM
  3. disconnect oil inj. on Merc 115 4cyl
    By 78Vector in forum Technical Discussion
    Last Post: 08-04-2004, 06:10 AM
  4. V-8, How to disconnect & remove VRO
    By PORT in forum Technical Discussion
    Last Post: 04-24-2004, 09:25 PM
  5. How do you disconnect shift shaft on Merc?
    By CDave in forum Technical Discussion
    Last Post: 05-04-2003, 08:21 AM
Diamond Marine
