Results 1 to 8 of 8
12-07-2019, 05:50 AM #1
Lower Unit with a different nose cone.
This lower unit came as an extra when I purchased my boat. Obviously the housing is trash. It's supposedly a 1.75 ratio and has a blowout ring of of some sort. The other abnormality to me would be the nose cone. It has three big holes and a rounded shape. I have only seen the pointy nose cones like Bob's. Anyone know where this duckbill cone would have come from? Is it any good, if you could/would take it off? Not sure what i am going to do with the unit yet. I will never use it, but I hate to see it sit around if it's of use to someone. I am sure it has a bunch of internal parts someone could definitely use.
We only go through this circus once...so enjoy the rides!!!
12-07-2019, 06:56 AM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
looks like a hydromotive.
12-07-2019, 07:24 AM #3
12-07-2019, 10:32 AM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
yes hydromotive and its not a torqmaster it first generation alpha 1st case following preload case's for it to be a 1;75 it would have to have been a special gear set from Mercury only no after market for hipo cases they sold them for sporty cles and torqmasters ive never had any of them
12-07-2019, 10:32 AM #5Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
is there a rear drain in carrier
12-07-2019, 08:45 PM #6
12-07-2019, 10:56 PM #7Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
YES its a drain screw same as what your looking at next to base of skegg! a torqmaster is the only case Mercury made with boss's where low water pick up hose are drilled out it was not available before 1995 it also has 4 intake holes on each side not 8 the drain only came on the three cases which had big bearing and heavy prop shaft carrier which measures 11/4 !! the 1647 9147 is fishing motor case i have rebuilt 100's of them
tux974 liked this post
12-08-2019, 04:09 AM #8
Nose cone on lower unit, help.
By 500dollar744ti in forum Technical DiscussionReplies: 14Last Post: 10-17-2013, 04:20 PM -
Lower unit repair (nose Cone)
By boater777777 in forum Technical DiscussionReplies: 1Last Post: 05-17-2010, 01:38 PM -
lower unit lenght with nose cone
By boilerdawg in forum Technical DiscussionReplies: 1Last Post: 07-02-2007, 08:15 PM
