Results 1 to 8 of 8
    Jul 2008
    Denton, Md.
    Lower Unit with a different nose cone.
    This lower unit came as an extra when I purchased my boat. Obviously the housing is trash. It's supposedly a 1.75 ratio and has a blowout ring of of some sort. The other abnormality to me would be the nose cone. It has three big holes and a rounded shape. I have only seen the pointy nose cones like Bob's. Anyone know where this duckbill cone would have come from? Is it any good, if you could/would take it off? Not sure what i am going to do with the unit yet. I will never use it, but I hate to see it sit around if it's of use to someone. I am sure it has a bunch of internal parts someone could definitely use.
    We only go through this circus once...so enjoy the rides!!!
    Dec 2001
    looks like a hydromotive.
    Jul 2008
    Denton, Md.
    Got ya, thanks Dave!
    Jul 2002
    FT WORTH, TEXAS
    yes hydromotive and its not a torqmaster it first generation alpha 1st case following preload case's for it to be a 1;75 it would have to have been a special gear set from Mercury only no after market for hipo cases they sold them for sporty cles and torqmasters ive never had any of them
    Jul 2002
    FT WORTH, TEXAS
    is there a rear drain in carrier
    Jul 2008
    Denton, Md.
    Quote Originally Posted by TEXAS20225 View Post
    No sir, not that I can see. I looked in there I assume the drain is easy to see? I have only had torqmasters through the years.
    Jul 2002
    FT WORTH, TEXAS
    YES its a drain screw same as what your looking at next to base of skegg! a torqmaster is the only case Mercury made with boss's where low water pick up hose are drilled out it was not available before 1995 it also has 4 intake holes on each side not 8 the drain only came on the three cases which had big bearing and heavy prop shaft carrier which measures 11/4 !! the 1647 9147 is fishing motor case i have rebuilt 100's of them
  8. Likes tux974 liked this post
  9. #8
    Jul 2008
    Denton, Md.
    Thanks Tex, I appreciate the information.
  1. Nose cone on lower unit, help.
    By 500dollar744ti in forum Technical Discussion
    Last Post: 10-17-2013, 04:20 PM
  2. Lower unit repair (nose Cone)
    By boater777777 in forum Technical Discussion
    Last Post: 05-17-2010, 01:38 PM
  3. lower unit lenght with nose cone
    By boilerdawg in forum Technical Discussion
    Last Post: 07-02-2007, 08:15 PM
