Results 1 to 3 of 3
    Nov 2019
    Augusta GA
    Single lever side mount controls vs two lever side mount controls?
    I need to replace my old mercury single lever side mount control and been wondering about a two lever shifter/throttle. Is it worth the upgrade to a twin, how difficult or if there is any pros and cons? The only time I had a single engine with 2 levers was back in the 80's on a boston whaler 11' and cant recall how it was, not sure how it would be now since I'm use to a single lever.
    Any thought between hardin marine https://www.hardin-marine.com/p-7440...e-control.aspx and dana https://www.marineindustrieswest.com...productid=4691
    Are they both good or is one better that the other?
    Thanks.
    Nov 2019
    Augusta GA
    BTW, is there a lock button so it doesn't accidentally get knocked into gear when idling in neutral or the opposite, when going cruising and shift it into reverse?
    Ft. Lauderdale, Fl
    Quote Originally Posted by Wellcraft26 View Post
    Thanks.
    You have a higher chance of breaking a gearcase by shifting while at high rpm if the throttle is advanced.......
  1. WTB Mercury side mount controls
    By CHEVYMAN434 in forum Parts Wanted
    Last Post: 10-21-2017, 07:55 PM
  2. How to reverse throttle lever throw on merc side mount shifter
    By AlaskaStreamin in forum Technical Discussion
    Last Post: 03-17-2003, 11:37 AM
