Results 1 to 11 of 11
Thread: Mercury 245
    Mar 2018
    NJ
    Mercury 245
    So tonight i bought my first Mercury 2.5-245-carb powerhead that is a drop on. I am hoping to get some feedback on the Good-the Bad & the Ugly of this powerhead. Always Truly Appreciate the Help & Suggestions/Recommendations from members. Thank you
    Sep 2017
    Ashland city tn
    Never owned one. but they say every 100 ish hrs rering. There a guy round here (granted he dont use much at all) but he has one on a bullet that he bought new in late 80s maybe a 90. (Not sure ) he told me never been apart. So all in all guess it's how its used and been used. Good luck with her tho.
    TX......somewhere?
    Quote Originally Posted by Merc 2.5 View Post
    first ones in '91.. were bottom guided stuff with pumper carbs..
    all still nic?..
    comp/leakdown?..
    year?..
    had several.. loved 'em.. easy ta tune/work on and virtually maintenance free as far as high performance junk goes...
  4. Likes tux974, Capt.Insane-o liked this post
    Jun 2012
    Indiana
    My first high performance outboard was a 91 2.5 245. Great engines but basically a 260 with carbs. So, re ring every 100 hrs etc. but good strong engines.
    Sep 2017
    Ashland city tn
    His came new on a bullet but was older bullet so I guess it was a 91. Only talked to the guy once so hard member the yr. but he loved it.
    jonesville, La
    Check the bores and see if nic is good, do a leakdown test also, can save alot of money if rings are bad. just good insurance, they run great
    Aug 2006
    GA
    I have no complaints. Run real Good..
  9. #8
    Sep 2008
    louisville
    I have a 91 245 carb motor and it’s a great motor ! Easy to work on ,simple to tune . I’ve owned it since 2008 and ran the piss out of it . Re ring every 80 hours . It’s on a fresh set never been started waiting for me to break in or sell . Pushed my allison grandsport to 96 mph @ 7200 rpm
    Attached Thumbnails Attached Thumbnails 25B61D8B-8793-4053-A62F-205472B7F8B2.png   BE4E6F6B-2F43-4D39-8779-E58DF322D235.png
  10. #9
    Aug 2006
    GA
    I had a nice 245 also. Let somebody talk me out of it. Regretted it ever day
  11. Likes pkstv, Capt.Insane-o liked this post
    Mar 2018
    NJ
    Thank you for the feedback everyone. My next questions are--I am pulling the heads to look at the walls and de-carbon the pistons,is it safe to run 34cc heads on this and do 25 degrees of timing. Thank you
    TX......somewhere?
    do your comp/leak down before ya pull tha heads.. will give ya base line ta compare anything ya do after tha fact plus will show some things tha eye won't with pistons still in it... 34's will work if pistons, rings and nic are all still good.. check for "steel" sleeve's..
    if not degreed, go with 22/23*…
    jus my suggestions, gl...……….……..
  1. Replies: 8
    Last Post: 03-16-2012, 05:43 PM
  2. Article: Mercury Racing Blog: Team Mercury – Part 3: Earl Bentz
    By Scream And Fly in forum vBCms Comments
    Last Post: 02-04-2012, 07:55 AM
  3. Replies: 0
    Last Post: 01-15-2012, 07:30 AM
