Results 1 to 11 of 11
    Feb 2011
    HUDSON, FLORIDA
    Nut driving me nuts
    HAVE a 1987 220 efi. i lost the lock nut that goes on the stud that holds the throttle cam[black] that moves the rubber roller, opening the shutters. it takes a 3/8 wrfnch. ive tryed 6 or more nuts, none has the correct thread. even robbed fron a 150 carb, no good. could it be metric? sae fine? tryed to find it in linkage tech guide manuals, no luck. engine# ob211002. also the little plastic bushing that slides on first. goin nuts!
    Dec 2001
    HeeHee ya need a squirell.....Might be metric......but if it came off with a 3/8 then not....How much bigger was the 150 nut?
    Feb 2011
    HUDSON, FLORIDA
    about the same, but wont thread on. mybe 10/32? if it was bolt, ide just go to hwd. store, but its in the block..
    Sep 2002
    Solvang, Calif
    If it isn't any of those it has to be......https://www.boltscience.com/pages/screw4.htm
    Outside of nut who cares.... Could be a 2" spanner with a 1/2" hole. Hardware stores usually have a hole and stud size tool set where the nuts and bolts are. Owned a 1984 F250 with a 460cid engine. When replacing the water pump found 1 bolt that was metric. Fun trying to remember the correct hole it went in.
    Gary
    Sep 2017
    Ashland city tn
    Is it the same on the 2.5? I have few nuts like that. got a pic of the stud?
    Ft. Lauderdale, Fl
    3/8" wrench size will be either a 10/32 (fine) or 10/24 (coarse), most likely a 10/32 as I have never seen a 10/24 on an outboard.
    Sep 2017
    Ashland city tn
    Yall all mine is 7/16ths wrench. And looks fine thread. Did u get a odd ball on that stud? The 2.4 and 2.5 carb is same stud. or mite b a carb thang. Have u tried something like a switchbox nut for the connections? I think those 3_8ths mite b standard cant member. If 1 of those nuts would work u could match it up at hardware for 1 way
  8. Thanks KIRCHNER thanked for this post
  9. #8
    Jan 2015
    The site I linked to has some very good diagrams with part numbers. Sometimes I order direct, sometimes the shipping is so much I take the part numbers to Ebay. Not sure if this is your motor in the link. If it is not, I am sure you will figure it out.
    http://www.marineengine.com/parts/me...nd-shift-shaft
  10. Thanks KIRCHNER thanked for this post
    TX......somewhere?
    from old time memory.. if its a 3/8 nut its gonna be 10/32.. if its 7/16 nut its gonna be 1/4 machaine thread.. only metric I remember ona 220 laser is tha two nuts on tha fuel pump stud connections???.. anything different is a screw up....
  12. Thanks KIRCHNER thanked for this post
    May 2011
    Oklahoma City, Ok
    3/8" wrench would most likely be 1/4 -20 or 1/4 -28 bolt.
    Measure the diameter, you will know from that measurement what it is.
    Also, make sure the 1st two threads are not burred up or dented.
    hope this helps.
    If you think this is fun, wait til next weekend!
  14. Thanks KIRCHNER thanked for this post
    May 2011
    Oklahoma City, Ok
    hummmm,
    Glad I could help!
  1. OK old Merc IL6 people. Got a question that driving me nuts.
    By Robby321 in forum Outboard and Racing History
    Last Post: 09-18-2014, 09:40 AM
  2. Driving me nuts!!
    By CKMATE225 in forum Technical Discussion
    Last Post: 07-18-2013, 05:46 PM
  3. Mercury Tech: This Merc 1500 is driving me nuts.
    By wired247 in forum Technical Discussion
    Last Post: 06-25-2012, 10:07 AM
  4. Hydraulic Leak!! (driving Me Nuts-i Know Short Drive)!!
    By bill mason in forum Technical Discussion
    Last Post: 03-29-2007, 05:04 PM
  5. Need Help Driving Me Nuts
    By BassRunner in forum Technical Discussion
    Last Post: 06-05-2002, 05:33 PM
