Results 1 to 6 of 6
    May 2008
    Merritt Island, FL
    300xs mount bolts
    2010 300xs. As I passed by my engine a day or two ago, I noticed a rusty area on the swivel bracket. I compared to the other side and the bolt had completely corroded, and it appeared the head was gone. Makes me question if these bolts are stainless, or I guess someone broke the head off that one prior to my ownership. I considered replacing with 1/2" stainless bolt , but then thought maybe the mount bolts are a diff grade bolt than standard 316 ss. I ordered new bolts from Merc, but wonder if anyone knows if those mounting bolts are stainless steel?
    Also, I need to remove the spiral retaining ring from the yoke to get these upper mounting bolts out. Not sure that I've ever seen a spiral retaining ring. Any tips before I use a flat screwdriver to back it out?
    Feb 2014
    Missouri
    If the anodes are shot it wouldn’t be impossible for even ss to electowhatever.
    I normally stick to merc bolts. to many stainless coated and alloys out there. Unless I’m positive one is better. Like the steering bolt.
    Not sure on the retaining ring books not handy to check befor I put my foot in my mouth. Sure it’s not a spring lock washer.
    Buy a new retaining ring too. The bolts are m12 x 190 and better ones can be sourced than what merc used
    Aug 2012
    Tenkiller Lake, OK
    Bolts
    ARP makes some really stout ones.
    May 2008
    Merritt Island, FL
    Thx, I will get a new retaining ring. Svc manual describes it as spiral retaining ring.
    For my serial no, it uses the old style bolt that is 1/2-13 instead of metric. Ah well, I'll just go w what I ordered as far as bolts go.
    Dec 2001
    My buudys boat was not turning left.....2.5 on CkMate......The bolt had broken and jambing in the swivel bracket......Check ya motors for lose/broken bolts.......the same motor..... f/w nut.....crank case bolts......I built it he pulls it apart.....
  1. 2.5 upper mount bolts?
    By revlimiter776 in forum Technical Discussion
    Last Post: 03-26-2015, 01:18 PM
  2. 20" offshore top mount bolts
    By Extreme in forum Technical Discussion
    Last Post: 07-30-2012, 07:47 PM
  3. 300xs top engine mount bolts
    By Revolution141 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-14-2012, 06:14 PM
  4. Motor mount bolts loosening up
    By Tail of the Rooster in forum Technical Discussion
    Last Post: 08-04-2009, 10:48 AM
  5. Can you still buy Top Motor mount bolts
    By lolmann in forum Technical Discussion
    Last Post: 06-26-2007, 10:46 PM
