Results 1 to 7 of 7
    What exhaust cut is this?
    Pulled the heads off of my 225 Promax and and curious as to what cut is this on the exhaust port? They arnt a arch but have a raised-heightened cut on each one of them. Is this stock or something somebody did?
    Attached Thumbnails Attached Thumbnails 20191202_063914.jpg   20191202_063957.jpg   20191202_064145.jpg
    Jul 2012
    Lufkin, Texas
    Maybe somebody just matched the port in the sleeve to the block without smoothing the radius? I would clean it up...
    8 Post(s)
    corrosion on the cylinder liner..
    Ya. Mota been sitting for 4 years
    Shreveport, La.
    Could be some very heavy chamfering. I agree with nitro_rat and clean it up. Make it uniform.
    Dec 2010
    Denmark
    The 2,5L Merc 260HP has a meassurement from top of port to top of block of 40,5mm
    If you could throw a mirror down there you might to be able to see if its hand made or factory made.
    Quote Originally Posted by A164 View Post
    Yes it measures 1.60" exactly.
  1. Replies: 1
    Last Post: 12-05-2013, 04:48 PM
  2. Mercury Tech: Gasket between exhaust can and exhaust plate/ 2.4 Bridgeport
    By Air Eddie in forum Technical Discussion
    Last Post: 12-29-2010, 04:16 PM
  3. offshore exhaust snout vs relieved exhaust
    By STVBOY in forum Technical Discussion
    Last Post: 10-11-2001, 07:57 AM
