Results 1 to 5 of 5
Thread: 1999 Mercury 300 Pro Max
12-01-2019, 06:07 PM #1New Member
- Dec 2012
- Lockport, NY
Repowering - $12,000 for everything
1-1999 Merc 300 Pro Max - 25" mid - 456 hours - ran good when removed
1-1999 Merc 300 Pro Max - 25" mid - ? hours - hole in piston/cracked block - was a rebuild
1-1999 Merc 300 Pro Max - hole in block from piston rod - 400 hours
1-2016 Merc Sportmaster - 1.62 CXL fat shaft - less than 10 hours
1-2016 Merc Sportmaster - 1.62 XL fat shaft - less than 10 hours
1-sportmaster - 1.62 - small shaft - 15" ? hours
1- Capilano Hyd Steering helm # 1275V - w/17' of hyd hoses and fittings for dual engines
2- Merc Offshore Props #48-825903-21 L&R hand
Dual set of gauges- Gaffrig II - tach, water press, water temp, volts, fuel level, fuel press, hour, Speedo, blue bezels
1- 4 slot Gaffrig tab & drive gauge blue bezel
1- Gaffrig 4 lever shifter w/cables 264"
1- tie bar 26"
2- oil tanks
2- trim pumps
All wiring for engines including keyed ignition switches - shop manual also
12-02-2019, 08:13 PM #25000 RPM
- Dec 2012
- Lancaster ky
- 250
Pm sent
12-07-2019, 09:00 PM #3New Member
- Dec 2012
- Lockport, NY
12-13-2019, 06:42 PM #45000 RPM
- Apr 2010
- Indian Lake Ohio
- 330
- 74
01-05-2020, 11:58 AM #5New Member
- Dec 2012
- Lockport, NY
Everything Sold
1999 Mercury 300 pro max
By George Paul in forum Technical DiscussionReplies: 8Last Post: 07-25-2017, 06:29 AM -
1999 Mercury 150
By traviss224 in forum Technical DiscussionReplies: 9Last Post: 02-09-2017, 02:44 PM
