Results 1 to 5 of 5
    Dec 2012
    Lockport, NY
    1999 Mercury 300 Pro Max
    Repowering - $12,000 for everything
ID:	453787Click image for larger version.
ID:	453788Click image for larger version.
ID:	453789Click image for larger version.
ID:	453790Click image for larger version.
    1-1999 Merc 300 Pro Max - 25" mid - 456 hours - ran good when removed
    1-1999 Merc 300 Pro Max - 25" mid - ? hours - hole in piston/cracked block - was a rebuild
    1-1999 Merc 300 Pro Max - hole in block from piston rod - 400 hours
    1-2016 Merc Sportmaster - 1.62 CXL fat shaft - less than 10 hours
    1-2016 Merc Sportmaster - 1.62 XL fat shaft - less than 10 hours
    1-sportmaster - 1.62 - small shaft - 15" ? hours
    1- Capilano Hyd Steering helm # 1275V - w/17' of hyd hoses and fittings for dual engines
    2- Merc Offshore Props #48-825903-21 L&R hand
    Dual set of gauges- Gaffrig II - tach, water press, water temp, volts, fuel level, fuel press, hour, Speedo, blue bezels
    1- 4 slot Gaffrig tab & drive gauge blue bezel
    1- Gaffrig 4 lever shifter w/cables 264"
    1- tie bar 26"
    2- oil tanks
    2- trim pumps
    All wiring for engines including keyed ignition switches - shop manual also
    Dec 2012
    Lancaster ky
    Pm sent
    Dec 2012
    Lockport, NY
    Sportmaster shorty was on 3.0
ID:	454105Click image for larger version.
Name:	Sportmaster shorty.jpg
    Apr 2010
    Indian Lake Ohio
    Quote Originally Posted by MERCMAN300 View Post
    Price ?
    I sent you a PM
    Dec 2012
    Lockport, NY
    Everything Sold
  1. 1999 Mercury 300 pro max
    By George Paul in forum Technical Discussion
    Last Post: 07-25-2017, 06:29 AM
  2. 1999 Mercury 150
    By traviss224 in forum Technical Discussion
    Last Post: 02-09-2017, 02:44 PM
