Results 1 to 15 of 25
    Just picked up 225 Promax for Viking
    Picked up this 225 promax last weekend from a fellow member here. I dropped a piston on my 2.4 a couple months ago so the search for new power was on. Didnt want to buy something without seeing it 1st hand so local was preferred. Saw this posted here and started messaging. 3 days later it was in my truck bed. Story was he had it on a tunnel boat and sold the hull and kept all the rigging and motor. Been sitting in garage for 4 years fogged. And needed it gone due to moving out of state. Seller seemed very honest . We started the motor and got it up to temperature. All good and shifted well and smoked a lot upon start up burning out the fogging oil.
    Got lots of the rigging too including.complete tilt hydraulic NEW system hot foot with cables gauges wiring harness jackplate and pump shop manual 24chopper 26 chopper and 29SRX all for 5K
    Attached Thumbnails Attached Thumbnails 20191125_110014.jpg   20191125_105939.jpg   20191125_105949.jpg   Screenshot_20191121-113517_Messages.jpg   Screenshot_20191121-113358_Messages.jpg
  2. Likes Dave Strong, CDave, Baja170 liked this post
    Sep 2017
    Ashland city tn
    Ya that was the one with repaired skeg but I thought was a great deal then all other stuff added , lot expensive props to
    Also did you ever finish your 2.4 150 build ? It was yrs ago and u was figuring out port work and such. I was reading on it earlier. and was wondering how that turned out
    Yes the 150 ran strong and flawless for 3 years at 6000-6500 every time out. But stuffed a piston and cracked the sleve and block last run.
    The lower unit on the Promax will be replaced hopefully with sportmaster. Anyone wanna trade for some rigging?
  5. Thanks Merc 2.5 thanked for this post
    Sep 2017
    Ashland city tn
    What kinda hydraulic steer is that. Guess stock merc?
    Quicksilver -Uflex never had oil in it
    When getting a motor that's been sitting for 3-4 years it started rite up and came to temperature. Is there a need to send off the injectors or ecu for cleanup and testing? I derailed the vst and was very clean fuel that came out already. But what else should I do ?
    NE Louisiana
    I would send the injectors off to be cleaned. Bud Conner has one of those flow meter cleaning machines, FYI. Check the rubber hoses and that would be it besides water pump, filter(s) and a good greasing.
    Those are great motors. Almost the same ports as a 245/260. Makes about 245 stock at least.
    Congrats!!!
  10. Likes tux974, Dave Strong liked this post
    Dont know what all has been done to the motor. It looks to have been split due to some gray sealant at the case half. Oil injection removed can is gone and mid drilled.
    Haven't pulled the heads off yet. Buddy is coming over with leak down tester. Well get that done then pull heads and look around. .
    What is stock port height on this 225?
    Attached Thumbnails Attached Thumbnails Screenshot_20191130-163304_Facebook.jpg
    Quote Originally Posted by roadkill636 View Post
    Those are relief holes in your leg for a bit more sound and exhaust relief in the leg. Mercury commonly did that in the 245/260 motors. Your liner is probably removed or they mounted the PM powerhead on a 245/260 midsection with 2pc plate which is good.
    According to your PH photo you are running a 2pc cooling so all is correct there.
  13. Thanks roadkill636 thanked for this post
    Likes roadkill636, Forkin' Crazy liked this post
    That's a great deal.
  15. Likes tux974 liked this post
  16. #11
    Central, PA
    Congrats on the great find! Helluva motor there
  17. Likes tux974 liked this post
  18. #12
    Pulled the heads off to take a look around and saw this on all the exhaust ports. They arnt a smooth round exit. They all have this extra cut in the top of them. Is this stock? What is this for?
    Attached Thumbnails Attached Thumbnails 20191201_202355.jpg   20191201_194029.jpg
  19. #13
    I guess I run it
    Attached Thumbnails Attached Thumbnails 20191224_202454.jpg   Screenshot_20191228-125846_Gallery.jpg
  20. #14
    NE Louisiana
    I don't know? Looks like some sloppy port deburring/champhering. All though this was a high performance motor, I don't think it got the attention the nic motors received.
    Those numbers look fine!!! So does the cross hatch in the cylinder. Run it!!!
  21. Likes roadkill636 liked this post
  22. #15
    Is there a diffrence in key harnesses? Mine from a 1988 carb 2.4 will crank this 2.5 but wont turn on the fuel pump.
  1. Look at what I just picked up !
    By outlaw 10.5 in forum General Boating Discussion
    Last Post: 06-28-2016, 06:52 PM
  2. picked up a Hydrostream Viking project
    By roadkill636 in forum General Boating Discussion
    Last Post: 01-29-2014, 11:29 AM
  3. Picked my Vector up!
    By QuarterHorse in forum General Boating Discussion
    Last Post: 12-06-2009, 07:48 PM
  4. picked up a new toy!!!
    By gettinwet in forum General Boating Discussion
    Last Post: 08-18-2009, 05:20 PM
  5. Picked up my new car Sat.
    By Ziemer in forum The Scream And Fly Lounge
    Last Post: 08-30-2005, 05:56 PM
