Results 16 to 25 of 25
12-28-2019, 09:50 PM #161980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
12-28-2019, 10:32 PM #17
Everything works fine with a brand new harness. But they both look the exact same. I dont wanna have to RIP out the harness out of the boat and all its gauges etc. So what's up with one harness not turning on the fuel pump?
12-28-2019, 10:52 PM #18
12-28-2019, 11:00 PM #19
Trying to post some wiring diagrams on my phone but wont let me. Will try tomorrow when I get on my computer.
roadkill636 thanked for this post
12-29-2019, 01:04 PM #20
Forkin' Crazy, tnelsmn liked this post
12-29-2019, 06:24 PM #21
Not really. Because everything on the engine side works. The fuel pump is the only thing that does not work when I plug it into my harness that's already completely installed and been running fine the past 4 years. Spark starter trim etc. It will start and run a bit when pumping the bulb but no electric fuel pump unless I plug in a diffrent remote key harness. Then fuel pump works. So if the purple is key on power why would it have spark and fire the injectors but not the electric fuel pump?.
12-29-2019, 06:42 PM #22
I lied to you after looking at the diagram the fuel pump has batt power to the + side of the pump the ECU provides a ground to make the pump run. Looking at the harness connector from your boat a few of the pins look squished. Take a razer blade or box cutter and push it down the split in the pins to spread them. See if that helps.
12-30-2019, 07:18 AM #23
Didnt u just have the same exact issues with the 220?
01-06-2020, 10:32 AM #24
01-06-2020, 03:00 PM #25
Look at what I just picked up !
By outlaw 10.5 in forum General Boating DiscussionReplies: 20Last Post: 06-28-2016, 06:52 PM -
picked up a Hydrostream Viking project
By roadkill636 in forum General Boating DiscussionReplies: 15Last Post: 01-29-2014, 11:29 AM -
Picked my Vector up!
By QuarterHorse in forum General Boating DiscussionReplies: 10Last Post: 12-06-2009, 07:48 PM -
picked up a new toy!!!
By gettinwet in forum General Boating DiscussionReplies: 4Last Post: 08-18-2009, 05:20 PM -
Picked up my new car Sat.
By Ziemer in forum The Scream And Fly LoungeReplies: 9Last Post: 08-30-2005, 05:56 PM
