Results 1 to 9 of 9
Thread: Cowl pin install onto block?
11-28-2019, 11:45 PM #1
Got this cowl pin and a 2.5 light weight cowl but it's not a direct bolt on. This fitting in the block is in the way. What am I needing to get this cowl pin bracket to bolt up to the top of the nlock?
11-29-2019, 06:04 AM #2
I should have a modded bracket and will get you a better picture showing what I do to make them work.
Maybe you can see I cut out a section in this picture below.
BTW, you mentioned a light weight cowling and that bracket you have is from a 280 alien cowling, it will not work or line up. Make sure if you try your cowling and has the hole already it will line up.
Frank Molé liked this post
11-29-2019, 07:07 AM #3
280 ??? Hmmm that's why the part of the bracket that bolts to the Top dont fit rite. That brass water fitting is in the way
12-06-2019, 06:06 AM #4
12-06-2019, 09:57 AM #5
Could you post pics of how it mounts to the top of the block at the flywheel?
12-06-2019, 10:49 AM #6
It mounts to popet pump fitting behind the flywheel.
Using the popet dump that is in your picture below picture is what I do to fitting and you will also need to trim the flywheel cover a little bit if you plan to run with it. You can use a 1/4-20 or 5/16"-18 bolt
NOTE; Use a short bolt so it does not block or interfear with water flow from popet.
roadkill636 thanked for this post
12-06-2019, 11:09 AM #7
Thank you Tux... that's exactly what I'm needing to see
12-06-2019, 11:15 AM #8
Glad to help.
Do not drill and tap on the motor. Remove the fitting and drill and tap on the bench so debri does not go into the motor.
Also you will probably need to adjust the pin height.
rock liked this post
02-20-2020, 07:09 PM #9
Got the correct bracket. Evidently I have a bracket for an Alian cowl wich is a bit taller than a 260 lightweight cowl... anyone need a aeolian cowl bracket PM me.
How to install 300x cowl and pan on non x mid
By LOSTINJ in forum Technical DiscussionReplies: 9Last Post: 02-02-2018, 11:55 PM -
Alien cowl install
By stivov1 in forum Technical DiscussionReplies: 5Last Post: 06-21-2017, 08:33 AM -
best place to send a block for a sleeve install ?
By WATERWINGS in forum Technical DiscussionReplies: 21Last Post: 04-20-2012, 07:23 PM -
Mercury Tech: How to install 2 piece adapter plate and engine block.
By bigboy in forum Technical DiscussionReplies: 1Last Post: 05-17-2010, 03:25 PM -
NOS evidence of install on block?
By B.Mac in forum Technical DiscussionReplies: 12Last Post: 06-15-2006, 09:00 PM
