Results 1 to 15 of 26
Thread: 2.5 promax fuel rail o-rings
11-27-2019, 06:16 PM #1New Member
- Jul 2012
- Eldersburg, MD
Anyone have any information on alternative o-rings that can be used when things are apart? Looks like I had some seeping going on from the 2 aluminum tubes that feed the fuel rail from the VST. Would also be nice to have info (part #’s)of the other o-rings involved when injectors are out for a cleaning.
11-27-2019, 09:20 PM #2
call brucato they have some
tux974, Dave Strong liked this post
11-28-2019, 06:22 AM #3
You can also try Fuller Marine (Vnemous) on here or a local injector cleaning shop if you have one.
11-28-2019, 01:18 PM #4
What Cody and Tony said, use the correct parts. nothing worse than a fire under the cowl out on the water.
11-28-2019, 06:34 PM #5
15029 - O-RING AND SEAL KIT ---- LIST PRICE $527.26 LOL
I go to a local seal and gasket distributor with a dollar bill and get the o rings and change back.
W2F a V-King, 90 5.0 liked this post
11-28-2019, 07:03 PM #6
ive tried some metric and standard orings from local auto parts store.. they didnt hold up
Dave Strong, tux974 liked this post
11-30-2019, 06:27 AM #7
11-30-2019, 10:16 AM #8
The real ones are usually green, brown or blue. And come in packs of 50 or 100 ..
11-30-2019, 10:19 AM #9
How about a part number or a source to purchase Mr Chaz??!!....
11-30-2019, 01:33 PM #10
Mr. Tee,
Unfortunately, Mercury used a few different injectors and fuel rails over the years. I'm not familiar enough with the 2.5 Pro Max to know exactly what they used. It would be irresponsible of me to take a guess ...
If you know the stem diameter, depth and width of notch in the stem and rail I.D. then it's easy to pick from the chart ....
Lots of sellers on Flea-bay. Some of the shops run specials or sell overstocked items.
Dave Strong, 90 5.0 liked this post
11-30-2019, 05:37 PM #11
That is so very nice to NOT be irresponsible.......
Just a little bit of info.
PM injectors are the same pink tip as the 300X and the 300PM white tips are the same size just a color change.
If you know the correct pink tip size for the X it will save me work... ...and help us all.....
Chaz, I would be a bit concerned about buying them from fle-bay. I like to do these plenum 1 time! Certainly do not want to find out that the person on fle-bay sold me something that was round and rubber but not good..........for fuel.... I would prefer an injector vendor as a source.
11-30-2019, 08:02 PM #12
Green are a/c orings..you want the brown o ring.
12-01-2019, 05:48 AM #13
12-01-2019, 11:35 AM #14
I was making a funny ..ill stop by zatkoff and get the sizes of them. They have them presorted for the vst and airbox. In Viton.
12-01-2019, 11:46 AM #151980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
3 liter Mad EFI intake, Fuel ECM, and Fuel Rail
By Mr. Demeanor in forum Misc. Parts and AccessoriesReplies: 3Last Post: 09-24-2018, 02:23 PM -
300 Promax Fuel rail
By strongback in forum Misc. Parts and AccessoriesReplies: 0Last Post: 09-03-2014, 09:19 PM
