Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    Quote Originally Posted by tux974 View Post
    That is so very nice to NOT be irresponsible.......
    Just a little bit of info.
    PM injectors are the same pink tip as the 300X and the 300PM white tips are the same size just a color change.
    If you know the correct pink tip size for the X it will save me work... ...and help us all.....
    Chaz, I would be a bit concerned about buying them from fle-bay. I like to do these plenum 1 time! Certainly do not want to find out that the person on fle-bay sold me something that was round and rubber but not good..........for fuel.... I would prefer an injector vendor as a source.
    Mr. Tee,
    It's never just that easy ... but lets start from the beginning ...
    The "pink" and "white" injectors are the same physical size Keihin ( Honda ) injector. The Pink is a "peak and hold" or low impedance and the "white" is a saturated or high impedance like the Deca style "pencil" injectors.
    Useless information for O-rings, but I know people who have tried to mix and match the outcome ... not so good
    90% of the O-rings .... come from China.
    The AC industry went from black to blue and brown when they went to R-134 . However you can get R-134 compatible O-rings in .... black
    As well as all color's for injectors .. including black
    No matter where you buy from, they need to be Viton ( fluoroelastomer ) to live.
    A Keihin stem is 7.5 x 10.25mm or .294" x .404" ( give or take )
    A std fuel rail is just shy of 10.5mm or .415"-.420"
    Which leaves you two ways to go ...
    A 7.5 x 1.5mm https://www.mcmaster.com/9263k568
    Or a #11 Merican https://www.mcmaster.com/9464k16
    Both of which also come in brown .. https://www.mcmaster.com/o-rings
    Which is a touch bigger, they are cheap enough in bulk ... so I keep both. Many aftermarket fuel rails are reamed just shy of 7/16 th's , so the Merican O-ring is a better fit ..
    Clear as mud ... ????
  2. Thanks .william1945 thanked for this post
    Likes Dave Strong, tux974 liked this post
  3. #17
    I always pre assemble the plenum, clamp it in a vice and run the pump for 15 minutes to check for drips or worse.
  4. Likes tux974, texasvector liked this post
  5. #18
    Capt, I made a hand pump setup and put around 20lbs to check before bolting to block. If they leak they do around 12-15lbs.
    Since my stuff sits for some time after building I hate to put fuel to them till ready to run.
  6. Likes Dave Strong, Capt.Insane-o liked this post
  7. #19
    Chaz, your killing me with that much rocket science info......
    I give up, to much info for me......
  8. #20
    Nov 2019
    Canada
    Chaz, these should fit right?
    If that's the case, to the original poster, message me your address and how many you want/need. I'll stick em in the mail for ya.
    www.InjectorService.com
    Call/Text - 204-326-0390
  9. #21
    Oohhh, good ta see ya usin fractions by-golly-there-ehh ...
  10. #22
    Now now Chaz stop picking on the Canucks. if i need a o-ring part number I'm hoping I can just give a brother a call? If i need to send some cannoli I'm good with that.
  11. #23
    Nov 2019
    Canada
    Well I had to convert it, I didn't want to confuse the Americans!
  12. #24
    Quote Originally Posted by Dave Strong View Post
    Dave, not pickin, I just wanted to speak in his native tongue ...
    Anytime brother, you know that ..
    Matter of fact, Canoli's on me ...
    One for you, one for me, and one for the injector guy who lives in N. America ..
    Serving Performance Boaters North America Wide!
  13. #25
    Jun 2009
    Bristol, Connecticut
    5/16 ID x 7/16 OD fit on the brass/aluminum parts of the 3.0L 225hp fuel rail? Do they fit the 225hp 3.0L injector tops too?
  14. #26
    Jun 2009
    I took off the injectors and brass tube o-rings, noticed both were different in size, the fuel injector o-ring was bigger than what is used in the rail angle piece
    The inner diameter of each of the fuel rail holes is the same though
  1. 3 liter Mad EFI intake, Fuel ECM, and Fuel Rail
    By Mr. Demeanor in forum Misc. Parts and Accessories
    Last Post: 09-24-2018, 02:23 PM
  2. 300 Promax Fuel rail
    By strongback in forum Misc. Parts and Accessories
    Last Post: 09-03-2014, 09:19 PM
