Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 66
Thread: ProMax Rebuild
  1. #31
    Jul 2008
    Denton, Md.
    So got to the last sealing ring and saw some significant wear. It had actually lapped over the the crank a bit. So should I replace this ring? I am concerned if I replace it the new ring won't match the wear in the block. If I don't I am worried about the wear, play, and it binding or not sealing very well. What ya guys think?
Name:	Wear Ring 1.jpg
ID:	455305 Click image for larger version.
Name:	Crankshaft Ring Groove.jpg
    We only go through this circus once...so enjoy the rides!!!
  2. #32
    Sep 2017
    Ashland city tn
    I see what looks like dents almost in crank journal in that pic. Hopefully camera making it look like that
  3. #33
    Jul 2008
    Denton, Md.
    Yeah Merc just beads of oil. PM'd pics look better I HOPE. James said throw a new crankcase sealing ring on there.
  4. #34
    Jul 2002
    FT WORTH, TEXAS
    it does not look like oil to me? i hope it is! if not this part will be your waterloo it will not survive if they are in fact irrgs in the surface
  5. Thanks Hydrodreams thanked for this post
  6. #35
    Jul 2008
    Denton, Md.
    Quote Originally Posted by TEXAS20225 View Post
    Thanks Tex, I know it's weird how it looks in the pics. I took these pics today with a different phone. They are smooth I cannot feel anything running my fingernail across them. I have also taken a plastic pick and slide it across them and nothing. The thing that concerns me are the brown streaks. I cannot feel them but wonder if I should use some crocus cloth and shine them up.
ID:	455458 Click image for larger version.
ID:	455459 Click image for larger version.
ID:	455460 Click image for larger version.
ID:	455461 Click image for larger version.
  7. #36
    Jul 2002
    FT WORTH, TEXAS
    its common practice to either scotch brite or use croakus(emory) cloth on these journals i use 800 grit every time however the brown will not hurt a thing glad it was not what it looked like
  8. #37
    Jul 2008
    Denton, Md.
    Thanks Tex, funny you mentioned that, I just tried a the finest Scotch Brite I could find (White) It lightened the brown streaks just a tad. I am going to lightly try some light grey or green to see how that does. I always just used emory cloth when rebuilding small engines but man with this gal and the RPMs they reach I want to smooth them enough but be the least intrusive as possible.
  9. #38
    Jul 2002
    FT WORTH, TEXAS
    not to worry you got this i remember my first rebuild i was no stranger to mercury v6's but never rebuilt one Tommy warren showed me how to do it and of course he held my hand all the way through it. I had years of experience rebuilding repairing tricking out merc lower units but when he dropped this in my lap it rung my bell and has dinged pretty much ever since. 101 is clean,clean,clean next is common sense if it looks suspect its already done, boat related expenses are not for the economy minded folks trying to make a drinking, fishing, drag boat come in the same wrapper!! and good, cheap and fast never shows up in the same sentence just my .02
  10. #39
    Jul 2008
    Denton, Md.
    Thanks Tex, I appreciate the help and everyone's input. I am taking my time, clean clean clean, and triple checking my double checks. I have learned a ton, enjoyed the work, and received some great advice. One of the best pieces of advice I got was the James Perry recommendation from you and many others. Like Merc 2.5 said about my block, don't worry you are in great hands with James.
  11. #40
    Jul 2008
    Denton, Md.
    Waiting on machine work I literally in less than 10 minutes with the finest Scotch Brite pad material shined up the crank rod journals. Then I lapped the reed cages and installed the new Chris Carson reeds. Lapping was a neat process. I know it's 101 for a lot of you guys, but seeing the difference in the deck heights was revealing. Once the lapping was done everything met perfect. My old reeds were cracked and chipped all over. Yet the ole ProMax seemed to run really good. I cannot wait to feel the giddy-up the gal will have!
ID:	455991Click image for larger version.
ID:	455992Click image for larger version.
ID:	455993Click image for larger version.
ID:	455994Click image for larger version.
ID:	455995Click image for larger version.
ID:	455996Click image for larger version.
ID:	455997Click image for larger version.
ID:	455998Click image for larger version.
  12. #41
    Sep 2017
    Ashland city tn
    You should also look into chris stuffers he sells. Ur crank rings on the way
  13. #42
    Jul 2008
    Denton, Md.
    Quote Originally Posted by Merc 2.5 View Post
    Got em Merc!! Thank you sir, did you get your envelope?
  14. #43
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Hydrodreams View Post
    Yes sir. I had forgot bout it til it showed up
  15. #44
    Jul 2008
    Denton, Md.
    Good deal, thank you man!
  16. #45
    Jul 2008
    Denton, Md.
    Well the ole ProMax block is on it's way back home. I will be putting her back together here soon! Woohoo!!!
Name:	Block Machining .jpg
    Meanwhile, I have been working on a few projects...
ID:	462828Click image for larger version.
ID:	462827Click image for larger version.
ID:	462829Click image for larger version.
ID:	462830Click image for larger version.
ID:	462832 The Ms's lil booster seat base.
ID:	462833Some wind deflectors to pull air in on those hot summer days.
  17. Likes JR IN JAX liked this post
  1. Promax rebuild
    By xpressman al in forum Technical Discussion
    Last Post: 05-05-2014, 01:16 PM
  2. 2.5 225 promax rebuild
    By baja1000 in forum General Boating Discussion
    Last Post: 03-06-2014, 01:13 PM
  3. Promax rebuild
    By joebassco in forum General Boating Discussion
    Last Post: 09-12-2010, 09:22 AM
  4. 225 promax rebuild
    By chad202 in forum Technical Discussion
    Last Post: 02-16-2005, 03:07 PM
  5. 225 promax rebuild?
    By Shawn L. in forum Technical Discussion
    Last Post: 11-26-2004, 11:40 AM
