Results 1 to 4 of 4
    Jul 2007
    Bermuda
    Mercury 50hp not loading in gear
    Hey everyone,
    I have a 2003 Mercury 50hp 2 stroke (serial# 0T926330) on a 16ft flats boat that has issues reving under load in forward.
    Sometimes will get up on plane and go(no clear corrilation from cold or hot), but they bogs down and wont go past a certain rpm. Will rev in nuetral and reverse fine, just wont load up in forward. cleaned the carbs new fuel filters, pump rebuild, disconnected yellow an black wire from rev limiter box, checked all sparks right after run...nothing works. Rpm gauge on boat not working so cant get a definitive rpm.
    Any ideas?*
    Sep 2017
    Ashland city tn
    Fuel fire and compression. Need spark gap tester. check compression b4 u do nething else
    Jul 2007
    Bermuda
    Sorry forgot to mention I had done a compression test, dont recall exact numbers but searched to see they were all good, consistent for all 3 cylinders. Changed spark plugs to factory quicksilver ones.
    Feb 2014
    Missouri
    What type prop hub, if it’s rubber check to see if it’s spun.
  1. mercury 50hp modds?
    By Adam Lee in forum Technical Discussion
    Last Post: 05-18-2010, 03:58 PM
  2. performance gear case 50hp omc
    By racecar001 in forum Technical Discussion
    Last Post: 11-23-2008, 01:30 PM
  3. 00' 50hp mercury
    By Jim_D in forum Technical Discussion
    Last Post: 06-26-2008, 06:12 PM
  4. Mercury 1998 250 Loading Up!!!
    By Ktrain in forum Technical Discussion
    Last Post: 11-01-2006, 09:47 PM
