Results 16 to 30 of 49
Thread: Promax block crack ???
11-26-2019, 03:24 PM #16
good man... reason I asked once I had a shop call to tell me they had cracked it on one side when they attached it to a fixture.. fixed it and put a weld on other side.. also good folks...
11-26-2019, 03:56 PM #17Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
JIm ruck did this to two of my 225 pmax blocks and james fixed one for me with the leg to support it i have seen them do the same thing on 200 efi blocks not too often but still required welding up im am thinking its produced by over tightening back two nuts also
W2F a V-King liked this post
11-26-2019, 04:16 PM #18
I'm still looking for the question that was asked in the 1st post... is there a water passage that this crack is near or in that will let water get into the exhaust chest and somehow get into the bottom cylinder?.
The motor has been running the past 9 years the owner stated.
I dont want to tare down the ph if it's just cosmetic and not going to hurt anything more staying like this
11-26-2019, 04:23 PM #19
Pulling mine down now. Never rebuilt 1997 ProMax with a bunch of hours. Has a crack in the same spot on the port side.
I will upload a picture later. Not close to a water passage for the above post. Just a thin spot in the block and you can see where mine has been exhausting through the crack.Last edited by Hydrodreams; 11-26-2019 at 04:26 PM.
We only go through this circus once...so enjoy the rides!!!
roadkill636 thanked for this post
11-26-2019, 04:55 PM #20
11-26-2019, 05:26 PM #21
This has been going on for a long time the 245/260 blocks were also notorious for cracking back there. Hence why long studs were introduced.
The 2 factors I have found to be the culprit are, removing the power head improperly and not using enough studs when using/installing to a fixture.
Roadkill, Never seen it affect water passage.
11-26-2019, 05:53 PM #22Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Just buy Yammi.....
11-26-2019, 08:46 PM #23
11-27-2019, 12:18 AM #24Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Not sure.... if Promaxk.... HeeHee......does.... twinnn gasket with a pan..... but that could.......if not....
11-27-2019, 12:27 AM #25Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
And...... Why...... do L6 Mercs have Cracks.... on the..... transfer hole........V6.... 150 and all....have cracks on the exhaust web??????Speek to Me Scotty......More power th tha front blasters.....silly bunny....Harminicks.......Sorry for the fact that I don't spell.....
11-27-2019, 06:22 AM #26
Hydro, I say that needs to be welded.
Dave,
Yes PM's have Hi-Perf double gaskets with either pan plate, old style and alien.
Yes, also common V6's have hair line cracks in exhaust web.
11-27-2019, 12:53 PM #27
tux974 liked this post
11-27-2019, 04:50 PM #28
Dave Strong liked this post
11-27-2019, 04:59 PM #29
11-27-2019, 05:43 PM #30
My plug on top of the block is blank. I thought all Mercs had their numbers stamped in there. What's up with this one?
1998 300 Promax block/crank/rods/pistons and 2.5 block with carbs
By Mhall222 in forum Outboard EnginesReplies: 3Last Post: 02-11-2019, 09:52 AM -
Mercury 2.5 200 block, (block is style that has the promax/260 type cut in exhaust)
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 5Last Post: 08-10-2015, 04:25 PM -
Mercury Tech: Mercury 300xs low compression block crack
By Bjorn08 in forum Technical DiscussionReplies: 8Last Post: 03-04-2015, 05:05 PM -
1983 Evinrude 115. Crack on outer block??? What to do???
By skeeterboy in forum Technical DiscussionReplies: 3Last Post: 07-26-2009, 10:26 AM
