Results 1 to 14 of 14
11-25-2019, 11:37 AM #1Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
How to bypass start in gear on mercury control box.
Trying to bypass start in gear. I know its the yellow with red stripe, but where do you cut and connect at? If anyone has a picture it would be appreciated. Thanks
11-25-2019, 05:00 PM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
i did mine, in the control box. you bypass a little switch. i wish i could be more helpful. cant remember s....
11-25-2019, 05:54 PM #3
carb a rator thanked for this post
11-25-2019, 08:03 PM #4Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
Thanks, i will get my apart this week. I bypassed one years ago but kind of forgot. Thanks for the pic.
11-25-2019, 09:13 PM #5
I never take the control box apart and do them there, I get a push button switch and wire to the engagement trigger of the solenoid and either mount the push button or hide it down in the gunnel.
Will start in gear with ignition on , or start normally if the push button isn’t triggered.
Less worry of someone else starting it in gear and a whole lot easier and faster to do.
rock, captblue99 liked this post
11-25-2019, 11:39 PM #6
Illustrate, please. I'd like mine to work both ways.
11-26-2019, 05:47 AM #7
I have been putting this off all summer long , didnt wanna crawl under dash to take box off , but am gonna soon , and I like sound of that push button deal.
11-26-2019, 08:40 AM #8
Hook one wire to the hot post at the starter solenoid (red wire) and another to the start post (yello w/red) and put a switch of some type in between. ezpz.
RockTeam Junk
90 5.0 liked this post
11-30-2019, 02:03 PM #9
I just sold my boat or i’d Take pictures of it wired this way.
Like rock said its super super easy.
Buy a push button momentary switch like the one bellow(many out there just one example)
https://www.amazon.com/Dorman-85984-...5140384&sr=8-3
get some wire and some wire ring terminals
run one wire from the large hot 12v on the starter solinoid to one side of the switch
the other wire from the small ring terminal (yellow wire) on the starter solinoid(this is the solinoid engagement pole) to the other side of the switch.
Super easy and dont have to take anything apart and can go back to 100% stock super fast too
Glasstream15 liked this post
12-02-2019, 10:04 AM #10
How about this-
For those of us with EFI motors that do not need the choke function on the key switch, wire the choke function in parallel with the safety switch. The switch would still function normally but if you desire to start in gear you push in the key. I haven't done it, but this idea came to me the other day. Thoughts?18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
12-02-2019, 10:32 AM #11Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
99fxst99.... sounds like a good one for injected motors..... try and cover so coastys can't find. I wish I knew a wiring trick could have made my motor start in gear..... all these years.....could have saved $$$ instead of buying SSM gear cases.......
12-02-2019, 11:50 AM #12
12-04-2019, 04:14 PM #13
I think that's a brilliant idea. It looks like if you have the yellow with bk tracer (pin 6) on the engine harness, it should not be connected and should have +12v when the key is pushed in. That's the choke wire for a carb motor and not used on EFI. If that checks out, just extend it up to the terminal on the starter solenoid that has the Yellow with red on it. Works normal (lockout) when you turn the key to start, starts in gear if you push the key in.
96 Cougar 23 MTR twin 300XS's. 100 something
98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
85 Baker RST 220 Laser SOLD
99fxst99 thanked for this post
12-06-2019, 10:56 PM #145000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
mercury v6 ignition switch wiring issue/bypass control box
By Varmint in forum Technical DiscussionReplies: 4Last Post: 05-17-2017, 06:10 AM -
By Varmint in forum Technical DiscussionReplies: 0Last Post: 05-14-2017, 10:15 AM -
???start in gear bypass switch???
By johnt in forum Technical DiscussionReplies: 13Last Post: 06-29-2005, 08:04 PM -
Question about creative idea for using a switch to bypass neutral start protection
By Ron V in forum Technical DiscussionReplies: 5Last Post: 06-24-2003, 08:42 AM
