Results 1 to 4 of 4
    Oct 2009
    Lake Conroe, Tx
    Return fuel line from regulator
    on a factory aluminum fuel tank. Connecting a return fuel line from the regulator to the tank without factory return fittings. I was thinking of using a T into the vent of the tank. Not sure any ideas? Thanks
    May 2014
    Livingston, Louisiana
    If possible it’s a good idea to drop a line/ hose down inside tank near bottom so that fuel enters below fuel level to cut down on aeration and keep fuel cooler. They make AN pass through fittings for fuel tanks that you can hook hoses to both ends of fitting using AN style fittings. This is only possible if you can gain access inside of tank through sending unit hole or something, a lot of marine style sender holes are too small. If it’s impossible to install pass through fitting, using vent may prevent adequate venting, maybe try returning to filler neck hose?
  3. Likes 90 5.0 liked this post
    Apr 2016
    Victoria bc canada
    It is also possible to run the return line into a filter housing such as a water fuel separator with an open port.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by Brookbbb View Post
    Just make sure the filter doesn't have a pump between the tank and it or you will restrict the return.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  1. fuel regulator return
    By fortlaudypower in forum Technical Discussion
    Last Post: 11-14-2015, 10:04 PM
  2. efi fuel return line help
    By tunnelwood in forum Technical Discussion
    Last Post: 07-21-2011, 03:05 AM
  3. Fuel Return Line - Rigging New Fuel Pump Setup
    By Hydrasports205 in forum Technical Discussion
    Last Post: 06-17-2005, 07:06 AM
  4. Holley blue with regulator, return line needed???
    By mxz in forum Technical Discussion
    Last Post: 08-28-2004, 09:00 AM
  5. Fuel return line?
    Last Post: 05-02-2003, 07:04 AM
