Results 1 to 14 of 14
Thread: Lower crank seal on v6 merc
11-24-2019, 09:26 PM #16000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Have another question; is there a seal of sort in the adaptor plate[2pc] or is the powerhead seal in carrier it? meaning the driveshaft just passes thru adapter cleanly?
11-24-2019, 09:50 PM #2Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
No seal for driveshaft in adapter. Clay
11-25-2019, 05:42 AM #3
Seal is on the crank only, nothing on adapter plate.
KIRCHNER thanked for this post
11-25-2019, 04:44 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
11-25-2019, 05:17 PM #5
#4 is what you see. Hammer it back into the crank
death is certain; life is not
tux974 liked this post
11-26-2019, 01:27 AM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
They fall off......Pain when trying to put lower unit back up if they have fallen off.....I use a round tapered rod to expand the ring so it fits in tight......and red loctight.....
11-26-2019, 05:37 AM #7
The guys above gave you the answer! Yes, its made to fit snug on the DS.
Its common to find them sitting on the plate or on the DS above water pump top or laying in the plate. Most times it will be on DS.
Actually many guys run without even knowing it fell off when it falls on the plate. I do not recommend running without one.
I have made a habit to peak up there when LU is off especially in salt water and short midsections.
I use a short broom handle with tapered end to sit the seal on and like mentioned with a little loctite tap it lightly back in place.
VERY IMPORTANT DO NOT TAP OR HIT HARD just enough to place it back! Also wipe outside of seal and inside crank so loctite will hold.
KIRCHNER thanked for this postFrank Molé liked this post
11-26-2019, 08:53 AM #86000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
got it , but about #5? would that be missing too? just want to get it right, ART. Thanks
11-26-2019, 10:29 AM #9
11-26-2019, 07:50 PM #106000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
11-27-2019, 06:04 AM #11Bud Conner "Heathen" "Defending Our Constitution"
11-27-2019, 02:29 PM #126000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Iso have that seal lock-tite back in, but i also have newseals that go behind that cast plate, attached by 4 1/420 bolts. to remove that plate read loosen block bolts? dont see any bolts except case bolts. guy posted he couldnt get that plate off. now im hesitant to try. looks simple but powerhead is hanging by flywheel. with the bolts out. can i grab the collar with channel locks, rotate it, while applying downward pressure? think other guy gave up, put the bolts back in. dont want open a basket of snakes at this point. but due for new seals im sure.
11-28-2019, 10:04 PM #13Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The bottom plaet/carrier....4 1/4 bolts..... just pry......change out seals.......the one on the crank falls off.... IMOP....because the crank has rusted..... biggeh hole..... that's why I deform the ss seal to fit tight..... red only works if ya clean up the crank hole real good......
11-29-2019, 10:38 AM #146000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
Lower will not go back on- 2.5 merc- lower crank seal came off
By CircleHook in forum Technical DiscussionReplies: 14Last Post: 09-18-2015, 09:37 AM -
OMC Tech: 1978 175HP Lower crank seal
By numlaar in forum Technical DiscussionReplies: 4Last Post: 07-16-2013, 04:27 PM -
Mercury 3.0L lower crank seal and end cap replacement
By Powmer in forum Technical DiscussionReplies: 4Last Post: 02-19-2012, 09:48 AM -
mercury 2.0 150 lower crank seal replacment
By arctic cat 1000 in forum Technical DiscussionReplies: 1Last Post: 09-19-2010, 04:10 PM
