Results 1 to 15 of 17
Thread: What is this hole for?
11-21-2019, 01:20 AM #15000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
In researching my no engine temp issue, I found this hole. What purpose does this serve? From what I can tell, it puts water straight off of the pump, into the same cavity that the poppet is when closed. Can anybody enlighten me on this?
11-21-2019, 07:04 AM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
let the block drain so it don't freeze......
rock, Glasstream15 liked this post
11-21-2019, 02:45 PM #3
It cools the bearing carrier in the lower unit ...
TNRoostertail liked this post
11-21-2019, 04:38 PM #45000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
11-21-2019, 06:02 PM #5
Welp , it's true. The early 3.0L had two small holes , that when clogged up with sand and seashells would cut-off the flow of the only cool water the bearing carrier would see, and subsequently, burn up # 22 and # 26 allowing water to enter the case. Over the years. I have fixed a bunch of the early plates by installing "standpipes" in the adapter plate.
On later models, the factory fixed the problem by installing a tall strainer # 10 in the exhaust tube.
On tuners that I build from scratch, I use a tall, stainless air tool muffler
The 2.5 is a better design. Instead of putting the water port down in a "cup" that can collect junk that can /will clog up the hole, they put the hole in the flat floor where water running along the path can easily blow little rocks and shells thru the cooling system instead of giving them a place to collect.
If you don't believe me, plug the hole. Go surface your favorite wheel for a good long weekend ... and then tell me how much water is in your lower unit oil ...
Forkin' Crazy liked this post
11-21-2019, 06:28 PM #65000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
This hole I’m talking about, appears to “shoot” up towards the bottom of the powerhead. How would that direct back down, and land on the bearing carrier? I’m really curious, send me some pics of what you are talking about.
11-21-2019, 10:45 PM #7
11-21-2019, 11:59 PM #8
The best picture you will find is in the service manual for your particular engine. It will show in detail the different paths the water takes to deal with keeping your engine cool in all circumstances.
As far as the hole facing up onto the excess/ return cavity. I would say it serves two functions. #1 Many outboards have a flow diverter where the water has cooled the exhaust chest and now enters the heads. I know the 3.0L has a hole on the other side of the diverter that puts water from the bypass cavity ( cold ) directly to the exhaust port side of the bottom two holes. ( a bee-line to hottest spot first )
#2 To keep the base gasket cool ... OK .. maybe three # 3 To purge air out, before it finds it's way up to the closed thermostats ... and turns to steam ..
nUmBrrrrr 4 .. Dave ... It wUz 65* tOdaa, Wutz thiz frozen wAtur you speek uv ....
If you look in the top and bottom of your tuner / exhaust tube you will see the hole / holes that feed water DOWNWARD that cool the lower unit. They might not be in perfect alignment with the hole in the adapter plate .. but you will see there they share the same cavity ...
FlaBum ... I think you told me that you worked for Mitch at the Ft. Liquordale dealership. It was red beard Mike, the service mgr. at the Jensen Beach store that taught me about collecting seashells ... Wow, gotta be almost 25 years ago ...
Sumptin bout diggin a Bahamian trench ....
11-22-2019, 12:03 AM #95000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
Ahh, gotcha. I’m following now. I learned something today, thanks.
11-22-2019, 01:30 AM #10Member
- Oct 2014
- Finland
- 55
- 7
- 15
Hi!
Speaking of bearingcarrier cooling, made my own version.
Blacknsilvr thanked for this posttnelsmn liked this post
11-22-2019, 09:49 AM #11
We're all only as good as our teachers ... only dumb people I know, are the ones born knowing everything ...
Let us know what you find with your temp issue .... keep in mind, one of those red dot temp guns is your best friend when tracking down temp problems ...
A couple pieces of hose that fit the thermostat dumps will also let you see where the water is going.
Again ... on the 3.0L (they have issues) they idle @ Zero to five psi of water pressure. If the port side thermostat hangs open it will bleed off all the water, while the starboard bank ( which is physically higher ) will only fill to the height of the port thermostat and start making steam, that overheats the top cylinder, that sets off the alarm. The last logical thing you would do is give it some throttle to bring up water pressure. But thats the only thing that will fill that side to the top.
If the starboard side is stuck open ( temp sender, if only one, is usually on that side)
that side will pass all the water, and never show any heat on the gauge, while in reality the port side is burning up.
Hupiveneilijä
Hi!
That's a smart move ...
Ignore the dumb joke I made to a friend about where to cut the water tube for a 15" mid ...
It might be a bit over-kill ... But I like to put the poppet bypass water thru the 3/4 inch tube on the right, directly on the carrier ...
Capt.Insane-o liked this post
11-22-2019, 10:50 AM #125000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
Will do. I think I have narrowed down to a poppet issue and idle rpm. We will see here pretty soon.
11-22-2019, 12:13 PM #13Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Chazzz... I had a crabber that his 50 hp merc wouldn't shift..... It had periwinkels jambing the shift/ lock cam....
11-22-2019, 05:25 PM #14
Escargo ... ?
Kinda like the sand flea's we use to catch Permit on in the shallows down here ...
11-22-2019, 07:04 PM #15The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
15" 2 Hole CLE Lower, 15" 4 Hole Lower, 25" 2 Hole Lower, CLE Case - Cleaning House.
By Pachanga_rick in forum Lower UnitsReplies: 9Last Post: 09-11-2015, 04:48 PM -
4 hole vs 6 hole XS gearcase
By Tom Smyth in forum Outboard and Racing HistoryReplies: 7Last Post: 12-22-2006, 07:13 AM -
2-hole VRS 4-hole CLE lower units...
By jrumon in forum Technical DiscussionReplies: 12Last Post: 04-15-2004, 10:42 PM -
Hole to fill in a hole in transom?
By Jeff_S in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 03-25-2003, 11:44 PM
