Results 1 to 9 of 9
    Oct 2009
    Gonzales, La
    Simon re-calibration (tuner) results on 350 Verado
    Oct 2009
    Gonzales, La
    My math says that the “455 hp” cal got him right at 400. Id be interested to see if the Simon 400 hp cal is THE merc 400r cal copied. I would trust that more than a custom cal, especially if it performed the same. Also note that he’s running the 5.44 HD lower unit (not HDSM) which is purported to hit a wall around 80, so that could be limiting his results.
    My buddy’s 24 motion has been 96 with twin 300hp verados 5.44 cases without nosecones. The boat is 1000lbs heavier than my 24 skater so it will never be a 110mph boat like you would expect but with some setup there’s no 80mph “wall”. The hd sm is the same diameter it’s all about big diameter and getting them 2.5”+ above. If it’s not in the water it doesn’t matter how big the case is
    Oct 2009
    Gonzales, La
    I wonder what his motion would run with a surfacing lower unit.
    Sep 2012
    How is he maintaining water pressure? Did he block off the upper holes?
    Quote Originally Posted by engineermike View Post
    115
    Nov 2010
    Hudson Florida
    Quote Originally Posted by Turborr View Post
    All upper intakes are welded up and the lower pickups have had work done to them. Bottom of boat has ramps too
    FLA
    We did a 340 flash on a 225 Verado with the large gear case on a Playcraft Daytona series 22Ft.. Boat with 250 Pro xs light would run 59 but Verado with the larger case only ran 53 after flash 64 great gain and the boat is a little faster than 300xs boat .
    24 Twister
    May 2009
    Ormond Beach, Florida
    It looks like they have tunes available for the new 4 strokes. Curious whether the flash program locks itself to one motor like a lot of the car tuners do since I have 2 motors (300R and 250 ProXS) I'd be interesting in "tuning". It also appears you can flash back to stock, I wonder if Mercury has gotten sophisticated enough to be able to detect it even when flashed back?
    Also wondering what gains they claim for these motors. I guess I'll give them a call.
    Mark
  1. Verado ECM upgrade and Simon Motorsports
    By ucf_motorcycle in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 05-19-2015, 06:41 PM
  2. MAD EFI Tuner & Simon popet diverter on 300XS?
    By MaDneSS in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-12-2012, 03:08 PM
