Results 1 to 6 of 6
    Oct 2009
    Gonzales, La
    Simon re-calibration (tuner) results on 350 Verado
    Oct 2009
    Gonzales, La
    My math says that the “455 hp” cal got him right at 400. Id be interested to see if the Simon 400 hp cal is THE merc 400r cal copied. I would trust that more than a custom cal, especially if it performed the same. Also note that he’s running the 5.44 HD lower unit (not HDSM) which is purported to hit a wall around 80, so that could be limiting his results.
    My buddy’s 24 motion has been 96 with twin 300hp verados 5.44 cases without nosecones. The boat is 1000lbs heavier than my 24 skater so it will never be a 110mph boat like you would expect but with some setup there’s no 80mph “wall”. The hd sm is the same diameter it’s all about big diameter and getting them 2.5”+ above. If it’s not in the water it doesn’t matter how big the case is
    Oct 2009
    Gonzales, La
    I wonder what his motion would run with a surfacing lower unit.
    Sep 2012
    How is he maintaining water pressure? Did he block off the upper holes?
    Quote Originally Posted by engineermike View Post
    115
  1. Verado ECM upgrade and Simon Motorsports
    By ucf_motorcycle in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 05-19-2015, 06:41 PM
  2. MAD EFI Tuner & Simon popet diverter on 300XS?
    By MaDneSS in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-12-2012, 03:08 PM
