Results 1 to 8 of 8
    Nov 2019
    Augusta GA
    Chopper propeller question
    I have a guy that is selling me a 14 1/2 x 26 chopper propeller part number 48 13370 a62 and since I'm not an expert by any means I would like to know if this could be a good starter propeller. The plan is to use it in a 1996 mercury 115hp next summer.
    What would be a good price for it, the leading edge needs to be smoothed out a bit.
    Thanks for any input.
    Sep 2017
    Ashland city tn
    Need more info on boat weight set up etc. but never seen a 115 turn a 26 successfully
    Prob weong spline also
    Windsor, Ontario
    I don't think you can run 14/5" diameter on your 115 - it is 15 spline, so that part is OK. Of course you could have the diamter reduced when you have the leading edge smoothed. What kind of boat? My usual advise is to start with a used Trophy. Even pitch.
    They fit, barely. You'll have to change the trim tab. Used to run a v6 chopper on my 100 i-4.
    Dec 2001
    Laser.......
    Windsor, Ontario
    Laser is a good choice if the height is not too high. Even pitch for the inline 4?
    Gothenburg, Sweden
    Quote Originally Posted by Wellcraft26 View Post
    I doubt there is a gear case for the I4 Mercury that would allow a 115hp engine to be able to push a 26 ft Wellcraft with any 26 inch propeller...__PRESENT
    Dec 2001
    Markus.... is not to be trusted..... the hat.... the red clothes,,..... he is Santa......Present.......Anyone Be good.... ?
  1. Replies: 0
    Last Post: 06-19-2019, 10:47 AM
  2. Replies: 0
    Last Post: 08-03-2015, 03:15 PM
  3. Propeller Question
    By Jason Johnson in forum Technical Discussion
    Last Post: 02-26-2010, 11:15 PM
  4. propeller question
    By gettinwet in forum Technical Discussion
    Last Post: 08-25-2009, 07:19 PM
Eddie Marine - Horizontal
