Results 1 to 7 of 7
Thread: Timing Indicator Question
11-18-2019, 09:51 AM #1
I did some searching but came up with quite a few results. What do you guys that build recommend for finding top dead center? I like to use a dial indicator normally but seen there are a few dial indicators made for the spark plug hole. Just looking for the best setup so I can check where my timing is on the 2.0 after I get the heads back on. You guys recommend 25 degrees for a 26cc head?
Respect no wake zones!!! Evinrude guys need a place to race too.
11-18-2019, 11:40 AM #2
Use a piston stop or dial indicator. If ya use a stop rotate crank clock wise until piston makes contact with stop and note degree reading ( I like stop length to be where this is around 10 degrees for simplicity) rotate counterclockwise until piston hits and note degree reading, should be the same amount of degrees ATDC as your reading BTDC. If not adjust pointer accordingly until they are the same. Same principle if you are using an indicator, just use the same reading in thousandths of piston travel in both directions to note readings in both BTDC and ATDC.
TNRoostertail liked this post
11-18-2019, 05:07 PM #3
Or get a jsre tdc guage. Cheap and very handy to have around. hes a vendor here
nitro_rat liked this post
11-18-2019, 05:24 PM #4
JSRE is a dial indicator that goes in spark plug hole, same procedure
11-18-2019, 05:39 PM #5
11-18-2019, 07:13 PM #6
Is this Jay Smith? If so im cool with that and thats one of the sets I was referring too.
11-18-2019, 07:16 PM #7
I have 2 starrett dial indicators but both are set up for different procedures and I dont want to take them apart lol. I will get one of these otw. The other set I saw was made by storm.
Jackplate indicator's question
By dompie99 in forum Technical DiscussionReplies: 1Last Post: 07-23-2014, 09:40 AM -
trim indicator question
By slikcraft in forum Technical DiscussionReplies: 1Last Post: 04-05-2004, 04:04 PM -
TDC indicator question
By WATERWINGS in forum Technical DiscussionReplies: 5Last Post: 05-25-2003, 12:50 AM -
Trim Indicator Question
By 22VelocityProMax300 in forum Technical DiscussionReplies: 1Last Post: 07-25-2001, 11:32 AM
