Results 1 to 7 of 7
    Sep 2017
    Knoxville, TN
    Timing Indicator Question
    I did some searching but came up with quite a few results. What do you guys that build recommend for finding top dead center? I like to use a dial indicator normally but seen there are a few dial indicators made for the spark plug hole. Just looking for the best setup so I can check where my timing is on the 2.0 after I get the heads back on. You guys recommend 25 degrees for a 26cc head?
    Respect no wake zones!!! Evinrude guys need a place to race too.
    May 2014
    Livingston, Louisiana
    Use a piston stop or dial indicator. If ya use a stop rotate crank clock wise until piston makes contact with stop and note degree reading ( I like stop length to be where this is around 10 degrees for simplicity) rotate counterclockwise until piston hits and note degree reading, should be the same amount of degrees ATDC as your reading BTDC. If not adjust pointer accordingly until they are the same. Same principle if you are using an indicator, just use the same reading in thousandths of piston travel in both directions to note readings in both BTDC and ATDC.
  3. Likes TNRoostertail liked this post
    Sep 2017
    Ashland city tn
    Or get a jsre tdc guage. Cheap and very handy to have around. hes a vendor here
  5. Likes nitro_rat liked this post
    May 2014
    JSRE is a dial indicator that goes in spark plug hole, same procedure
    Jul 2012
    Huntington, Texas
    A universal spark plug dial indicator set may not have sufficient reach to work in this application. I recommend picking up the JSRE set for simplicity's sake!
    Sep 2017
    Knoxville, TN
    Is this Jay Smith? If so im cool with that and thats one of the sets I was referring too.
    Sep 2017
    Knoxville, TN
    I have 2 starrett dial indicators but both are set up for different procedures and I dont want to take them apart lol. I will get one of these otw. The other set I saw was made by storm.
  1. Jackplate indicator's question
    By dompie99 in forum Technical Discussion
    Last Post: 07-23-2014, 09:40 AM
  2. trim indicator question
    By slikcraft in forum Technical Discussion
    Last Post: 04-05-2004, 04:04 PM
  3. TDC indicator question
    By WATERWINGS in forum Technical Discussion
    Last Post: 05-25-2003, 12:50 AM
  4. Trim Indicator Question
    By 22VelocityProMax300 in forum Technical Discussion
    Last Post: 07-25-2001, 11:32 AM
