Results 1 to 15 of 24
    Nov 2004
    South Haven, MN
    Does Mercury still make choppers?
    Looking for an in-line 14 x 22 RH chopper for my bass boat. Does Mercury still make/sell them?
    Windsor, Ontario
    No to choppers except the small one for 60 HP
    Feb 2003
    Rochester, NY
    There's a reason they don't make choppers anymore. Much better (new) designs make them pretty much obsolete. Have you considered anything else?
    1992 Progression 22
    Mercury Racing 250R
    Nov 2004
    South Haven, MN
    I'm currently running a Turbo1. Tried a Raker re-hubbed for my Yammy but it was slower than the Turbo1. Any suggestions? I have a 1995 Nitro 170TF with a 130hp Yamaha and a CMC jackplate with 5-1/2" setback.
    Oct 2009
    Gonzales, La
    Tempest+ or ProMax?
    Nov 2004
    South Haven, MN
    The 14-1/2" diameter ProMax will not turn on my Yamaha 130hp.
    Feb 2003
    Rochester, NY
    Quote Originally Posted by dpf-01 View Post
    Personally, I'd just call Brett at Bblades. He'll give you the straight scoop and eliminate the guess work.
    1992 Progression 22
    Mercury Racing 250R
    Gothenburg, Sweden
    I think I have a 24 inch labbed Mod-VP cut Mercury Chopper if that is of any use.__PRESENT
    Calgary, Alberta
    I have a regular V6 22” chopper that I’ll sell cheap, it’s box stock. They can be cut down, I did that in the past to run on an OMC V4 which will only accommodate 14” diameter props. The inline choppers worked well but were getting harder to find.
    Matt
    Nov 2004
    South Haven, MN
    Thanks for the offers...But what would be the prop that replaces the chopper now??? Guys that have in-line six's what are they running???
    TENN.
    i may have a prop that would work P.M. me and we`ll see
    Paul Freeman
  12. Likes Michael J Giesler liked this post
  13. #12
    Jun 2018
    Floating around
    Over hub? Lightning ET, Cleaver, Spinelli
    The first Lightning ET's were apparently cut choppers. Old racers were cutting props all the time and I guess the factory Merc camp liked what they saw and made factory offerings of the same styles. For pleasure craft use I like through hubs better. I cant seem to get the over hubs to bite worth a damn coming out of the hole.
  14. #13
    Jul 2012
    Huntington, Texas
    Is your exhaust relieved? If not, the exhaust coming out over the center of the blades will cause the prop to "blow out." Also some "negative" transom wedges for more down trim can help give some extra bite. I have never had problems with bite out of the hole but all my mids are drilled like a pro max with the liner removed...
  15. #14
    Windsor, Ontario
    Laser is 13 1/2 even pitch small hub. They run well at lower engine heights. Is your motor 4.25" hub diameter? If yes, stick with even pitch Lasers. Same with old Trophies. The evens were 13 3/4 small hub, the odds were big hub. I think the newer Trophy Plus are all small hub.
    At any rate, the Trophy is my starting point. There are better props but for a $300 (used) all round prop it's hard to beat a used Trophy.
    I used to lover the inline choppers, but they are ancient now and hard to find.
  16. Likes Capt.Insane-o, JBS liked this post
  17. #15
    PARADISE /Naples
    Omc srx
    We have invented the world WE see
  1. L&R 30p torq flo mercury choppers
    By Edit Marine in forum Propellers
    Last Post: 10-01-2019, 08:20 PM
  2. Chopper Prop: Mercury Choppers L. & R. Rot. 26 pitch
    By kentz in forum Propellers
    Last Post: 09-10-2018, 11:42 AM
  3. make choppers into et's
    By eli in forum Technical Discussion
    Last Post: 09-16-2004, 10:29 PM
  4. does mer or anyone else still make choppers for small motors??
    By ghost28 in forum General Boating Discussion
    Last Post: 08-30-2004, 02:13 PM
