Results 1 to 10 of 10
Thread: 2.5 Piston Mods
11-16-2019, 08:44 AM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
2.5 Piston Mods
Is there any pistons modifications on a 2.5-200-FF-block that will tweak it a little more during a rebuild. Having rod slots done and mild porting,balancing pistons and rods. Thank you
11-16-2019, 03:14 PM #2
Dont think many mods can b had to 2.5 pistons to increase hp. The 2.0 and 2.4 motors are piston ported and 2.5 is behind liner porting. Pistons for 2.0 and 2.4 can b modded tho.
As far as adding holes in 2.5 piston would just lighten it up. I believe that's the way it works. Maybe someone has done sumthin outside the box idk. Gud luck
11-17-2019, 03:06 AM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
what m 2.5 .the old ones.... were pron to be ported the 2.5 are behimd so no gainJMO.....
11-18-2019, 03:57 PM #4
Ifin the skirt closes off the mouth to the transfer port as the piston is approaching BDC, chances are pretty good ... that you have some work to do ...
Merc 2.5, Capt.Insane-o liked this post
11-18-2019, 06:02 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
20 years ago......
11-18-2019, 07:20 PM #65000 RPM
- Mar 2018
- NJ
- 196
- 10
I have a set of ART pistons i am looking to use,what is the difference if any from other case pistons. Thank you
11-18-2019, 09:41 PM #7Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
arts are good.......
11-19-2019, 09:22 AM #8
Maybe longer .... 1879
https://en.wikipedia.org/wiki/Two-stroke_engine
11-19-2019, 02:56 PM #9Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
ya tellin on me......
11-19-2019, 11:37 PM #10
3 piston trim vs. single piston trim mercury
By Coryc in forum General Boating DiscussionReplies: 32Last Post: 04-28-2017, 10:27 AM -
Piston Mods
By zzzman in forum Technical DiscussionReplies: 1Last Post: 03-01-2006, 10:22 AM -
JSRE piston/rod/wrist pin mods...how much do they help?
By STV_Keith in forum Technical DiscussionReplies: 4Last Post: 06-26-2003, 01:30 PM -
4 stroke Piston or Rotary- why even think piston for outboards
By mk30h in forum General Boating DiscussionReplies: 10Last Post: 11-17-2002, 08:02 PM
