Results 1 to 15 of 15
    Jun 2012
    Stream splashwell delete
    Hello everyone i bought my first hydrostream this year and im getting ready to finish the core and transom removal but having never done this before i would love to see some pics of where to make cuts on the splashwell and possibly some in process pics of a splashwell delete. My plan is to do all the dirty work and pay someone to lay the core, transom and stringers. Just dont want to make it harder on the guy doing the glass work due to my inexperience
    Be nice to Terry, he's a good egg
    Mar 2009
    Port Saint Lucie
    Did you take the cap off the boat?
    Central, PA
    Quote Originally Posted by 89Talon18 View Post
    So you should plan on removing the top cap as mentioned above. When I built my vector, I thought all was fine until i was replacing floor under the bow deck and pushed up hard enough to hear cracking and a bunch of old cabosil and filler break away to daylight, leaving me withering task of removing all old and filling and glassing with epoxy resin to put it back together properly.
    As far as where to cut the splash well out, I'd say cut the "tub" out leaving the forward cross member as a guide for where to end the new flat deck.
    This whole process would also be a great experience to dive into the world of fiberglass. Would also save you a ton of money that could be put towards a very nasty engine! Good luck and ask any questions, there are plenty of hydrostream guys here who have been through this whole process start to finish.
    Post a few pics too!
  5. Likes tnelsmn liked this post
    **** no on removing the deck. There is no reason for that kind of misery.
  7. Likes josh7_78 liked this post
    Mar 2009
    Port Saint Lucie
    Ha, every rebuild I've done is easier if the cap can come off. If it can't for some reason than so be it. But it's way easier with no cap. I've never done one without removing the cap, so I won't be much help.
    Minneapolis MN
    I couldn't imagine doing my current build with out pulling the deck. The whole deck removal/install should only add a week or two to the process.
    I cut out the core years ago before Terry bought it. Other than the gel being baked the boat is cosmetically very nice. The rub rail is near perfect. There is no need to remove the deck.
    Minneapolis MN
    Makes sense trying to save the rail. Mine was already shot, still working out how to replicate it.
    Jul 2012
    Lufkin, Texas
    IMO saving the rail is the only reason not to split. If the original gel isn't good enough to save I wouldn't consider trying to save the rail. Solid paint looks better with the black rubber rail IMO...
    Mar 2010
    Holly
    Here is what mine looked like after...
    21 Skater w/ 250SHO
  14. #12
    Mar 2009
    Port Saint Lucie
ID:	452865Click image for larger version.
ID:	452866Click image for larger version.
ID:	452867Click image for larger version.
ID:	452868Click image for larger version.
  15. #13
    Mar 2009
    Port Saint Lucie
ID:	452870Click image for larger version.
ID:	452871Click image for larger version.
ID:	452872Click image for larger version.
ID:	452873Click image for larger version.
  16. Likes nitro_rat liked this post
  17. #14
    Mar 2009
    Port Saint Lucie
    Since I popped my cap, I glassed in the piece of foam on the top before I cut the well out, I popped the cap off cut the old well and then I glassed the bottom of the foam underneath.
  18. Likes nitro_rat liked this post
  19. #15
    Jun 2012
    Thanks for responding guys. My plan is not to split the boat because it dose have near perfect rubrail and despite the non skid finish the bottom is very straight and also the pad is in great shape too, my thoughts were to leave it together, may be a pain to finish the removal of the core and transom but would help keep the boat rigid and hold its shape during the process of putting the stuff back in. Im just a little gun shy on the cutting part right now and wanting to do my homework before i commit on the cuts
  1. Splashwell delete question
    By Slimm in forum Technical Discussion
    Last Post: 06-11-2014, 09:37 AM
  2. glassing over the splashwell
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 09-11-2013, 01:03 PM
  3. newb question: why splashwell delete?
    By pcrussell50 in forum General Boating Discussion
    Last Post: 04-28-2013, 04:16 PM
  4. What is this......Splashwell
    By nbvalero in forum General Boating Discussion
    Last Post: 09-14-2010, 05:52 PM
  5. Splashwell delete
    By QuarterHorse in forum Fiberglass and Composites Discussion
    Last Post: 03-05-2010, 06:34 PM
