Results 1 to 6 of 6
    Black Creek WI
    Wh 46 slush tube, baffled Carbs And other 2.4 bp stuff
    The carbs came off a 2.4 bp, 86 main jet with linkage and throttle arm. I also have a the five peddle cross drilled intake with reed cages and front half from the same engine. Inner and outer exhaust cover with coils. Heads that need work. Some pistons and rods. I do have quite a bit 2.4 stuff that I would like to see find a new home and if it helps a member out, all the better. If interested or if your looking for misc. 2.4 stuff shoot me a pm and I will look over my hoarders stash. send pic's via text Keep the dry side up
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
    Mar 2018
    NJ
    I am in the process of rebuilding of a Carb Bridgeport,do you have a contact number. Thank you
    Black Creek WI
    Quote Originally Posted by tabme View Post
    sent a PM
    Black Creek WI
    Carbs, linkage and thottle arm are SOLD, other stuff plus more still available
    Black Creek WI
    Whatsamerc you have a pm
    Black Creek WI
    ttt
