Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
    Nov 2019
    Virginia
    Twins would look kool.......but just as or more than a good single....see what you can find such a omc 70 hp......You can't run a gearcase in R to get twins... it will wipe out the gearcase.
    I was thinking about the running in reverse thing; I mean, is the same gear size and ratio as the forward, rotating on same shaft, same pinion, same lock from clutch dog, the rear bearing shouldn't be an issue, gear oil shouldn't be a problem. Removing the little stop limiting thing on the stator/Throttle plate should aloud me to get the same throttle/RPM in rev as in Fwd. My .10 cents
  2. #17
    Nov 2003
    Portsmouth VA
    You don’t have a thrust bearing that absorbs the forward thrust when running in reverse. We have all either tried it, using your rationale, or know someone who has. If you still don’t believe us then find a left hand prop (good luck) and go for it. Let us know how that turns out.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  3. Likes Samrod liked this post
  4. #18
    Jul 2005
    AZ
    Damn it where's the pic posted recently of prop on backwards..
    But anyway
    I don't think your going fast enough to worry about both being right hand....a little steering torque is better than trashing a lower unit...and not going to surface it so won't crab
    Only time I've seen it done they locked/welded(not really sure) it in gear so was started in gear no neutral etc.
    And even then not sure they lasted
    '84 Checkmate Convincor
    Twin v6 closed deck Evinrude loopers Ported,2.7 heads,cooling mods
    milled finger ported to match vertex pistons,
    All casting slag removed
    Sleeves in opposite so no idle reliefs
    Offshore exhaust mids
    148 psi comp,balanced pistons and rods,Stuffed, 106 pullovers
    CDI 8500 digital ignitions ..Boyesen reeds..And more....
  5. Likes Samrod liked this post
  6. #19
    Nov 2019
    Virginia
    Quote Originally Posted by 99fxst99 View Post
    You donít have a thrust bearing that absorbs the forward thrust when running in reverse. We have all either tried it, using your rationale, or know someone who has. If you still donít believe us then find a left hand prop (good luck) and go for it. Let us know how that turns out.
    Oh right, i'm new and learning, will take you'all advice.
    - (If) I mount both 35's, I will have to rig some kind of wide Jack plate, preferably 1/2 Alum, to either independently or lift both at same time. I have a pair of cobra Hydro cyl but only one pump w relays, any ideas?
  7. #20
    Jul 2005
    AZ
    Quote Originally Posted by Samrod View Post
    Do a search on here just had a thread on setting up twins like that..1/2 plate and one pump
    Or can use a single switch if pumps/plates travel at same speed or close..just need to make a harnesses with one way diodes..
    I've had mine setup on single switch..have uflex paddles( and 3 different places too)
    Just have to rarely put them all the way up or down to make sure they are level...working on indicators (cause I'm to broke to buy them lol)
  8. #21
    Jul 2005
    AZ
    Would definitely look cool as hell with twins!!
  9. #22
    Nov 2019
    Virginia
    I see you got some trim tabs on both sides, How hight from the bottom edge you place them? Also, can they be fix or have to be on some king of cyl/actuators?
  10. #23
    Nov 2019
    Virginia
    I Like it better with triplets;lol
  11. #24
    Jul 2005
    AZ
    Mine are mounted an inch up from bottom..
    You can get them in fixed (not alot if help if you need to adjust)
    Smart tabs "SMART TABS adjust automatically according to overall boat weight. The five-hole adjustment built into each trim plate can be customized to produce more stern lift if needed. To do this, increase the lift pressure by moving the actuators away from the transom to a higher number on the plates."
    hydraulic trim tabs ...
    And also electric trim tabs..
  12. #25
    Jul 2005
    AZ
    Yea and the 9.9 in the middle is interesting..(just different cowl on a 15?)
    And they all look to be RH.. can't see the middle to well
  13. #26
    Dec 2001
    Tripps.....Eney Miney Mo.... which ones going to BLOW.......
  14. #27
    Nov 2019
    Virginia
    I was taking them to the river for testing, one a the time. I got to drive 30 min to closest marina in order to test run my motors, it sucks.
    I don't trust the bucket or water hose, I had plenty of motors that ran better than a new one in it and once I put it on the river on a 100 pound Jon, i couldn't even get to 10mph... and no, I don't weigh 600lb...lol
  15. #28
    Nov 2019
    Virginia
    Thanks for all the tips you given. I'm just trying to trick one or two of my 35's so i can hang with the guys running 40-90's. I don't see anyone with trick-out small outboards where i am. Just once a month, the guys with the big guns come out to play on the James River, from Richmond to Norfolk
    Your boat looks V shape. Mine is kind off flat in the rear from side to side. You think i could still benefit from trim tabs?
  16. #29
    Jul 2005
    AZ
    Me?
    Yes it's a 1984 25' checkmate convincor 24* deadrise
    Notched transom and a slight vee pad..makes running in big/ruff water more comfortable..
    Yes you would benefit from tabs even with a flatter bottom boat...if you need them
    Do the motors have power trim?
    BUT I would get motors mounted and setup and see where your at..
  17. #30
    Nov 2019
    Virginia
    Where can I find out the gear ratio of 1950-1960 evinrude/johnson from 5 to 40hp. Looking specifically for 1963 40hp evinrude.
  1. OMC Tech: 1983 Evinrude 35HP how to replace clutch dog?
    By Sparkieboat in forum Technical Discussion
    Last Post: 05-18-2015, 07:46 PM
  2. OMC Tech: After 10 mins. of running 1978 35hp evinrude starts falling off???
    By skeeterboy in forum Technical Discussion
    Last Post: 06-30-2009, 07:07 PM
Eddie Marine - Horizontal
