Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 67
  1. #46
  6. Likes 89LASER liked this post
  7. #51
    Quote Originally Posted by tnelsmn View Post
    How are you holding the layers together while laminating? Looking good!
    ...Both pieces are bonded in with that pink bedding compound also, if that's what you are also asking. the bedding compound, as it comes out of the five gallon bucket is white, but Gio used red M.E.K., so it ends up being pinkish after mixing. Generally speaking red catalyst is used for resin you use in glass lamination, clear catalyst is used when used in gelcoats, so it doesn't affect the color.
  8. Likes tnelsmn liked this post
  9. #52
    Mar 2009
    Port Saint Lucie
    It was measured for a 25", I remeasured after the bracket was out of the way, it does need to come up a little. From the top of the bracket to the bottom of the hull its 25+ inches. And with the adjustment on the motor it should sit good.
  10. #53
    Mar 2009
    Port Saint Lucie
    The layers of coosa were screwed together while curing. The Pink stuff is Arjay bedding compound. It is white with red MEK. And Yes Gio does very neat work, so at every step of the way people can see how neat its done.
  11. #54
    Mar 2009
    Port Saint Lucie
    Looks great from the photo's, Gio does nice glass work. Cant stand seeing peoples photo's of glass work, and the glass work is all glossy, which means an overuse of resin, and is a waste of money, weight & laziness and also a weaker layup. Gio's work shows no glossiness at all, which is excellent. One of my pet peaves, when my guys were glassing in stringers and/or floor panels, was to first make sure that the empty hull was not twisted on its carts/cradle/floor. Easy to forget this & fudge-up. In Port St. Lucie, who are you sourcing your Coosa board from & what density Coosa did you go with, for the transom? Composites One, Merritt Marine Supply, or?
    We get supplies from Merrits in pompano. I hear Fiberglass Florida has good prices too. The transom and knees are 2 layers of 1" 26lb coosa, the decks are 3/4 14lb coosa.
  12. #55
    Mar 2009
    Port Saint Lucie
    As far as the extra resin, we rib roll it out really good, squeegee when we can, use putty to help hold air bubbles at bay and put 1.5 oz mat over most things to absorb any excess and blend it all together. By the time you put the mat down and roll over it once, it's pretty much wet out. It also makes grinding and cleaning it all up easier.
  13. Likes tnelsmn liked this post
  14. #56
    Quote Originally Posted by Gorilla0178 View Post
    ...Can tell all this from the photo's and it all looks so nice this way. This is the way its supposed to be done, that so many laminators don't do. Gio knows his s h I t. Excellent job.
  15. #57
    ...As a "general" rule on a new hull outboard rig job, I have always used this input, with proven success. Water rises 1'' off the trailing edge of the boat at 60 m.p.h., for every foot of setback. This has always worked on every one of the "hundreds" of single, twin, triple, and quad outboard boats that I have overseen rigging on. Admittedly, I have never rigged a V-6 outboard boat that went as slow as 60 m.p.h., but this gives you a proven starting point for installing a bracketed boat, or an engine bolted directly to the transom. Hope this helps.
  16. Likes XstreamVking liked this post
  17. #58
    Mar 2009
    Port Saint Lucie
    That's exactly what I heard. I'll measure it again with more specifics. The bracket is 18" plus the 6" or so below the bracket. Then the approx 4" of adjustment on the motor bracket, I would have a jack plate for more adjustment. So I think itll fall into a good height.
  18. #59
    Mar 2009
    Port Saint Lucie
    Tank is in and foam is glassed in the cooler.
    Attached Thumbnails Attached Thumbnails 20200119_142136_1579529280540.jpg   20200119_113717_1579529278675.jpg   20200115_153111.jpg   20200115_153057.jpg
  19. Likes tnelsmn, 89LASER liked this post
  20. #60
    Mar 2009
    Port Saint Lucie
    Not much going on with the Craft lately due to other work. The tank is glassed in and I made a different console for it this one fits it a little better. I believe we're going to add a flat face to part of the console, prob in front of the steering wheel, so a larger screen can be mounted to it.
    Attached Thumbnails Attached Thumbnails 20200303_153129.jpg   20200303_153142.jpg   20200303_153156.jpg   20200303_153211.jpg
  21. Likes tnelsmn, 89LASER liked this post
  1. 20’ seacraft
    By Geosta in forum Hulls up to 20'
    Last Post: 07-25-2018, 02:26 PM
  2. 21' seacraft
    By magnum2.5 in forum General Boating Discussion
    Last Post: 03-29-2018, 10:34 AM
  3. seacraft transom
    By ezkeyz in forum Fiberglass and Composites Discussion
    Last Post: 03-14-2009, 08:09 AM
  4. 20' seacraft what do we need .
    By Reaction19 in forum Props, Setup, and Rigging
    Last Post: 07-23-2008, 04:17 PM
  5. Seacraft Cat ?
    By Powercat in forum Outboard and Racing History
    Last Post: 10-11-2002, 12:42 PM
