Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 67
  1. #31
    Mar 2009
    Port Saint Lucie
    The decks are glassed on the bottom, stiff enough to walk on already, rough cut still. The foam was shaped and glassed over. The front half of the hull has fresh matt over it. The rear seat it pretty much fit. Still tight in the corners. There is a white line across the top of the transom, it'll be cut straight across at the line.
    Attached Thumbnails Attached Thumbnails 20191223_153014.jpg   20191223_152947.jpg   20191223_091644.jpg
  2. Likes tnelsmn, 89LASER liked this post
  3. #32
    Mar 2009
    Port Saint Lucie
    Console built. Had to scrap together some of the promat, and use some other core mat cloth but it works. Needed it built to see if it fits. It needs core on a couple spots if we're going to use it.
    Attached Thumbnails Attached Thumbnails 20191226_152235.jpg   20191226_152204.jpg   20191226_152145.jpg   20191226_122644.jpg   20191226_122637.jpg
  4. Likes tnelsmn, 89LASER liked this post
  5. #33
    Mar 2009
    Port Saint Lucie
ID:	455111Click image for larger version.
ID:	455112Click image for larger version.
    Bracket in its approx location. Needs to go up a little bit.
  6. Likes tnelsmn, 89LASER liked this post
  7. #34
    Mar 2009
    Port Saint Lucie
ID:	455114Click image for larger version.
ID:	455115Click image for larger version.
ID:	455116Click image for larger version.
    Tank, still needs painting.
    Just a couple extra pics.
  8. Likes tnelsmn, 89LASER liked this post
  9. #35
    Mar 2009
    Port Saint Lucie
    Bulkhead glued in
    Attached Thumbnails Attached Thumbnails 20200103_155929.jpg   20200103_155903.jpg   20200103_155833.jpg
  10. Likes tnelsmn liked this post
  11. #36
    Mar 2009
    Port Saint Lucie
    Insulated the hull in the front for a cooler/fishbox.front front deck with hatch landing/ hatch. Rough cut gunnels.
    Attached Thumbnails Attached Thumbnails 20200108_155458.jpg   20200108_155450_HDR.jpg   20200108_155442_HDR.jpg   20200108_155404.jpg   20200108_155351.jpg
  12. Likes tnelsmn liked this post
  13. #37
    Mar 2009
    Saint Lucie Florida
    Looks great from the photo's, Gio does nice glass work. Cant stand seeing peoples photo's of glass work, and the glass work is all glossy, which means an overuse of resin, and is a waste of money, weight & laziness and also a weaker layup. Gio's work shows no glossiness at all, which is excellent. One of my pet peaves, when my guys were glassing in stringers and/or floor panels, was to first make sure that the empty hull was not twisted on its carts/cradle/floor. Easy to forget this & fudge-up. In Port St. Lucie, who are you sourcing your Coosa board from & what density Coosa did you go with, for the transom? Composites One, Merritt Marine Supply, or?
  15. #39
    Again, hard to accurately tell from the photo's, but if your going with a 25'' motor...that bracket position can go up quite a bit more, lol. Like I said though hard to say from just a photo.
  16. #40
  1. 20’ seacraft
    By Geosta in forum Hulls up to 20'
    Last Post: 07-25-2018, 02:26 PM
  2. 21' seacraft
    By magnum2.5 in forum General Boating Discussion
    Last Post: 03-29-2018, 10:34 AM
  3. seacraft transom
    By ezkeyz in forum Fiberglass and Composites Discussion
    Last Post: 03-14-2009, 08:09 AM
  4. 20' seacraft what do we need .
    By Reaction19 in forum Props, Setup, and Rigging
    Last Post: 07-23-2008, 04:17 PM
  5. Seacraft Cat ?
    By Powercat in forum Outboard and Racing History
    Last Post: 10-11-2002, 12:42 PM
