Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
  1. #46
    Apr 2015
    saskatchewan
    gf doesnt cry anymore lol, but she needs to gain 120lbs to balance me out if im using her as a counterwieght.
  2. #47
    Jun 2018
    Floating around
    Careful what you wish for
  3. Likes derpid, tnelsmn liked this post
  4. #48
    Apr 2015
    saskatchewan
    dont you hex me lol
  5. #49
    Minneapolis MN
    Hate to link to another forum but I feel it applies here. Ron added a pad to an old Glastron. But with the current power he has its not enough to get the hull up and on the pad. Food for thought.
    http://hydrostreamforums.com/viewtopic.php?f=6&t=3609
  6. Likes David - WI liked this post
  7. #50
    Ontario, Canada
    Quote Originally Posted by derpid View Post
    Soooo id like to hear some feedback from guys who have added a pad or lifting strakes, or both to a vee hull. was it a terrible idea? did it work out as planned? would it be better to add the strakes over the pad or the pad over the strakes? any advice? Boat is a '92 seaswirl spyder 188
    Adding a pad to a vee hull can provide some performance benefits, but doesn't necessarily help on just any existing vee setup, as it depends on several factors. (Some hulls the mod can help, but others it may not). In any case, the pad modification requires that the pad be specificallyy sized for the existing vee hull design, weights, power, etc. The required pad sizing (length, width, height, shape, edge design) to support sufficient Lift to make a performance benefit is the key to successful vee pad mod's that will actually improve performance and also exhibit sufficient dynamic stability. There's also some 'technical' issues to consider (eg: height optimization), since you're starting with a vee hull and 'adding' a pad, rather than integrated pad.
    Here's a couple of articles that gives some explanations...
    "How a Vee-Pad works"
    and "Pad Sizing"
    also... here is a video of VBDP software comparison of "Pad vs No-Pad" analysis example. (video is using an older version of software, so the newest software versions have even more features, but process still the same).
    Last edited by Jimboat; 05-30-2022 at 06:26 AM. Reason: added video of software analysis example
  8. Thanks derpid thanked for this post
    Likes David - WI, tnelsmn liked this post
  9. #51
    Minneapolis MN
    Jim- "How a V Pad Works" link isn't working.
  10. #52
    Ontario, Canada
    Quote Originally Posted by tnelsmn View Post
    OK, i think it's working now.
    (it' one of the articles that i did for Scream & Fly... more here.)
  1. Adding a photo
    By zues2167 in forum Posting Questions and Suggestions
    Last Post: 10-12-2014, 08:47 PM
  2. Adding a lip to a pad?
    By aaronmt73 in forum Props, Setup, and Rigging
    Last Post: 12-05-2013, 02:22 PM
  3. Adding Pic's in a PM
    By Jim_Pat in forum Technical Discussion
    Last Post: 03-23-2011, 09:37 AM
  4. what does adding cup do?
    By hydroViper235 in forum Technical Discussion
    Last Post: 06-25-2008, 11:44 PM
  5. adding a pad ??
    By baja237 in forum General Boating Discussion
    Last Post: 10-26-2001, 02:08 PM
