Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 52
    Jan 2018
    Alabama
    Yes, Allison. I think it's an XR2001 or perhaps a SS2000. One weighs 650 lbs, the other 900. Mine is a XB2002 and weighs 1,250 lbs with the short-shaft Merc.
  2. Likes Will hedrick liked this post
  3. #17
    Apr 2015
    saskatchewan
    very nice. i cant compete with my fatt 19ft, but its purdy and i like the layout.
ID:	452640 Click image for larger version.
  4. #18
    Oct 2018
    Tennessee
    Quote Originally Posted by Gordon02 View Post
    My xb02 is a little heavier than that, prob. A 100 or so with the etech
    (Rip. Whiteally02) -dad
  5. #19
    Jul 2004
    Connecticut
    Quote Originally Posted by derpid View Post
    in other words, probably not worth the hassle?
    For what you have correct. not worth the hassle. Post a better high res picture of the keel.
  6. #20
    Apr 2015
    saskatchewan
    lets try this
  7. #21
    Jun 2018
    Floating around
    Try some different props that thing is wet. I can’t see why you can’t get a lot more air under it with set up changes
  8. #22
    Apr 2015
    saskatchewan
    I’ve tried every prop I can get my hands on over the last two years except for a full on cleaver. But with a L1 gearcase a guy can’t really surface it enough to see the benefits (also kinda scared she might get right sideways if I do). Tried messing with less set back this summer with no success, it would likely benefit from 2-4 more inches of set back but I was not in the mood to order a 10 or 12 inch bracket this summer and re rig for the 7th time to see lol.
    This is kinda why I was thinking about modding the hull design with either more strakes or a pad, 14” setback should be enough to air it out a little.....
  9. #23
    Apr 2015
    saskatchewan
    Little better photo, but she’s still pretty wet.
  10. #24
    Oct 2018
    Tennessee
    You said you were 3" below pad. Keep an eye on your water pressure and come up in 1/4 to 3/8 increments. How far have you brought it up before?
  11. #25
    Apr 2015
    saskatchewan
    running hyd jackplate w/ water psi gauge so ive tried every height i can without sacrificing water pressure. it seems to loose the walk with higher engine heights but it doesnt seem to lift as well. if i remeber corectly with where i have it bolted curently i can jack all the way up to 1" above, maybe a tad more. it just seems to settle the best around the 3ish inches bellow the pad. running higher doesnt seem to do much more than make a cooler looking roost.
  12. #26
    Oct 2018
    Tennessee
    I was curious, I was running a coned m2 and have recently got an L2 factory, m2 1/4 below and the L2 I'm prob 1 1/2 to 2 " below for w.p. reasons, I will cone it eventually , the L2 is a faster unit i.m.o., your L 1 have 1.71 gears by chance?
  13. #27
    Apr 2015
    saskatchewan
    i was mostly currious on the value of adding a pad to an existing hull, it would likely help it fly better in the long run but it seems like that might be a very long and costly run to get it there. as far as setup goes i just kinda got tired of tweaking last summer and just let it be and enjoyed the water at 65mph. i believe that a tad bit more setback is the key (as ive ruled out less) but going further than 14" on the OG transom didn't seem like the right idea and it just barely fits in the shed as is lol.
  14. #28
    Oct 2018
    Tennessee
    Lol least its garage kept, I would agree with Gordon, cost/time would be great for not much gain,
  15. #29
    Apr 2015
    saskatchewan
    Quote Originally Posted by Will hedrick View Post
    running the 1:87 gears to my knowledge.
  16. #30
    Oct 2018
    Tennessee
    Nice there was a short time they built them with 1.71, almost like the brp. Holy grail, hard to find, people not want to sell them when they get them
  17. Likes derpid liked this post
  1. Adding a photo
    By zues2167 in forum Posting Questions and Suggestions
    Last Post: 10-12-2014, 08:47 PM
  2. Adding a lip to a pad?
    By aaronmt73 in forum Props, Setup, and Rigging
    Last Post: 12-05-2013, 02:22 PM
  3. Adding Pic's in a PM
    By Jim_Pat in forum Technical Discussion
    Last Post: 03-23-2011, 09:37 AM
  4. what does adding cup do?
    By hydroViper235 in forum Technical Discussion
    Last Post: 06-25-2008, 11:44 PM
  5. adding a pad ??
    By baja237 in forum General Boating Discussion
    Last Post: 10-26-2001, 02:08 PM
