Results 1 to 15 of 17
    Sep 2017
    Knoxville, TN
    Cylinder Head Machine Question
    I want to start off by saying this is the formula I used in the past to acquire correct cc's on my drag bike heads so it may be incorrect for marine 2 stroke applications. To learn how much material to remove to achieve the desired cc's I practiced this method with good results. I personally always installed the spark plugs I would be using to fill the void before starting. I then found true zero on the head ( setting the head dead level) and injected the desired cc's of liquid into the head. With the liquid static and not moving I would scribe the water line onto the casting. I then used calipers to find how much material was between the scribe mark and head deck. This would give me a starting point to shave for the cc's I wanted. I also measured each cylinder just to make sure they were close, and most times added the 4 and divided by 4 for the average. Is this an acceptable way to get started on marine 2 stroke heads as well? Thanks
    Respect no wake zones!!! Evinrude guys need a place to race too.
    Apr 2011
    Long Beach
    The correct way to CC heads is to use a piece of glass or plexyglass to drip your water into and when water makes contact with the whole underside of the glass...it's full. Surface tension and the "cap" on an open bath of water will give you screwy results.
    You can do some quick math to get you in the ballpark...measure the OD of the combustion chamber in the head, pi r sq to determine the area, then multiply that by the depth of cut, but with tapered chambers, this is a ballpark at best.
    I typically test first, then take off .020" and test again. That gives me an idea of how much farther to go. Keep in mind, the more you take off, the greater the gain per cut.
  3. Thanks KIRCHNER thanked for this post
    Sep 2017
    Knoxville, TN
    Right on, I understand the correct method to get total cc's on a head. I was just throwing out the method I use to get close to the mark before doing a total cc test.
    Water crawling up the wall is known as the "meniscus layer". While it will throw off your final number, it will do so on the low side. leaving a bit of a built-in safety margin.
    https://www.usgs.gov/special-topic/w...center_objects
    Most outboard's have a "top-hat" type chamber, meaning that the walls are parallel. So each cut will remove the same volume from beginning to end. Keeping in mind that the quench pad be it a flat recess or at an angle will need to be cut back in.
    The short answer is for most .007 to .010 will equal 1 cc . Which is a useful "rule of thumb" while machining. It is far better to know the compression before taking the motor apart , target compression you are looking to arrive at and then use the bore, stroke, rod length, exhaust port height and deck height to do a before and after "trapped volume" number.
    Sep 2017
    Knoxville, TN
    Right on, thanks for the feedback. I used to use my above method just to get close, then I would use the math to determine the remaining .000 that needed to be cut. Good info Chaz and lbh
    Florida Keys
    That green beer out of the Flannigans cup?
    '95 STV "The Blue Goose"
  8. Likes TNRoostertail liked this post
    Sep 2017
    Knoxville, TN
    Whats the difference between a 2.4 1 piece and a 2.0 1 piece if any? Thanks
    Quote Originally Posted by mach351 View Post
    LMAO .... St. Patty's day (night) does bring in some doozies .. and some floozies ..
    But the green beer foam throw's my numbers way off ...
    CVS wintergreen alky ... so my old azz can see it fill before ... Oooppss too late ..
  11. Likes mach351 liked this post
    Jul 2002
    FT WORTH, TEXAS
    most of the time smaller cylinders gets smaller diameter combustion chambers but not always i just pulled a set of a late model 2.0 fat block it had 787 C2's on it which have 2.1/8 diameter chamber on them (approx) i also have set of 488 C4 that have 2/18 combustion chamber on them and its not the first time i have had same casting number on heads that have different diam. combustion chambers i did not cc them they may have been deeper to get the 38cc they were supposed to be but its Mercury so some time its a surprise. the two piece heads had 31/8 and 33/8 cast in them 2.0 and 2.4 which was visible from the out side
    Sep 2017
    Knoxville, TN
    Right on, thx Tex
  14. #11
    Dec 2001
    The Hemi heads.... the flash point is close tha surface.... heat loss.... the flat tops the spark is closer to the gas charge........put in gap plugs... the flash point is closer to the max gas..... JMO
    Sep 2017
    Knoxville, TN
    So you would run a gap type plug with cut heads instead of a flat top?
  16. #13
    Dec 2001
    You missed what I was saying....Early merc heads were hemi style......later were flat....and the spark closer to the mass of charge.....IMO better .... that's why merc went that way.....and later motors had gap plugs..... closer to the center of the charge......than surface plugs.....I don't know if it makes a diff..... just what merc did it improve their motors.....the old hemi heads last longer.... as they are die cast.... the one peace rot out........if old salty....JMO
  17. Likes TNRoostertail liked this post
  18. #14
    I'm a fan of the "half a golf ball" (hemi) combustion chamber.
    The reason they got away from them is , because that design is less tolerant of low octane fuel and ignition timing than a "top hat" style chamber.
    maybe too much of a good thing on this vintage chamber .. LOL , they brought it up to the 1970's
    I did a few sets of weld-up's. I think anytime you can make the same or more power on less timing and fuel load ... your heading in the right direction ...
    These old "over the hill to grandmother's house we go" crossflows, always seem to run real "dirty" . I never had one, anybody know how much timing they needed ?
    To get the party started early enough to try and burn all the charge ...
    I would imagine ... a lot.
    Slugs look heavy too .... Built-in rev limiter ...
    I'm sure they made good torque off the bottom, but fell off early ...
    Some of the "new tech" idea's make sense , others look pretty bizarre ...
    Mild ....
    To wild ....
    Yamaha made wide use of the Toroidal chamber , with good luck ...
  19. Thanks TNRoostertail thanked for this post
    Likes TNRoostertail, mach351 liked this post
  20. #15
    Sep 2017
    Ashland city tn
    Chaz. Can u weld up sum 2.5 heads and make em hemi like old 2 piece. Will that still work?
  1. head gasket and cylinder head
    By drtyTshrt in forum Technical Discussion
    Last Post: 03-26-2017, 08:47 PM
  2. OMC Tech: Evinrude V8 Cylinder Head Question
    By Westtexan in forum Technical Discussion
    Last Post: 03-14-2017, 09:52 AM
  3. 1985 Johnson 140 cylinder head question
    By 1987Bee in forum Technical Discussion
    Last Post: 01-12-2017, 06:53 PM
  4. Mercury Tech: Cylinder Head Question 2.4-200
    By dwiggl in forum Technical Discussion
    Last Post: 07-08-2011, 02:42 PM
