Results 1 to 5 of 5
    Aug 2019
    Australia
    Flywheel problems
    So my flywheel dropped a couple of magnets and played havoc at the top of my motor. Now I am having lots of problems finding a suitable one to replace it. The motor is a donor powerhead and I can’t find a serial number on it anywhere (I believe that’s on the clamp which is long gone). The engine is a Merc Black Max 175 2.5l carb approx 1992. The flywheel is a red thing with 24 splines. Will any flywheel with the right splines suit or is magnet placement a big issue?
    Aug 2019
    Australia
    I do not suggest to play with magnets. Just get a black cast iron 40amp flywheel. With a 175 your not going to feel the difference!
  4. Likes tunnelmike, Glasstream15 liked this post
    Any 40 Amp Mercury V6 Flywheel will work. NOW!!! When you say "played Havoc on the top of your motor" Did it damage the stator or trigger when it dropped the magnets? If so you might need more than just a flywheel.
  6. Likes tux974 liked this post
    Aug 2019
    Australia
    Yeah, it’s killed the stator... the trigger is okay. My main concern was the lack of commonality between flywheels... and the part number doesn’t seem to exist. If anything will work, I’ll find one pretty easily nearby. Thanks for the tips
  8. Likes Glasstream15 liked this post
  1. stator/flywheel problems
    By snicrep in forum Technical Discussion
    Last Post: 06-15-2018, 02:31 PM
  2. Flywheel/starter problems...timing?
    By play2win in forum Technical Discussion
    Last Post: 08-25-2011, 04:37 PM
  3. Problems with Johnson flywheel
    By crewchief18 in forum Technical Discussion
    Last Post: 08-06-2011, 08:06 PM
  4. Crossflow gold flywheel problems
    By FlowMaxx in forum Technical Discussion
    Last Post: 07-31-2007, 02:27 PM
  5. Problems getting my flywheel off.
    By ronnyd8719 in forum Technical Discussion
    Last Post: 12-16-2006, 11:35 AM
