Results 1 to 5 of 5
Thread: Mid 1980''s 200up. 2.4 mercury
11-12-2019, 06:47 PM #15000 RPM
- Jun 2003
- 299
Lost two impeller tips off water pump impeller...one about 1/8" & one about. 1/4" ...where is the most likely location that they could end up....?there are no thermostates...if I remove the heads ...what are the chances I might see something.....the motor is ..offshore efi..updraft 245 hp...very good condition....& I don't want to hurt it.....
11-12-2019, 06:54 PM #2
Exhaust divider
tunnelmike liked this post
11-12-2019, 07:00 PM #3
Adapter plate... What he said^^
MichaelLast edited by mrichartz; 11-13-2019 at 10:03 AM.
'84 Checkmate Convincor
11-13-2019, 08:24 AM #45000 RPM
- Jun 2003
- 299
Thanks capt insane-o...do I need to remove the exhaust divider? Or will the rubber tips go out the exhaust square ports @ the bottom?
11-13-2019, 09:56 AM #5
I've seen small pieces of wood get stuck between the exhaust divider plate and the block. The divider has larger holes than the return into the block on a 2.5. Not sure about the 2.4. I've also seen plenty of crap end up in the adapter plate. You will have to remove the exhaust divider plate to check there and of course remove the powerhead to check the adapter plate. Mike
Cheaters never Win !!!
Seastar Pro for 1980 2.4 Mercury 200
By maineidyl in forum Technical DiscussionReplies: 6Last Post: 04-26-2015, 08:54 PM -
1980-81 Mercury 200-225 V-6 Block
By Eagle One in forum Misc. Parts and AccessoriesReplies: 5Last Post: 01-09-2014, 12:43 PM -
1980/81 Mercury 225
By Motion22 in forum Technical DiscussionReplies: 10Last Post: 10-13-2013, 05:06 PM -
IllinoisRiverRat 1980 Champion Swift/1980...Prop setup
By IllinoisRiverRat in forum Props, Setup, and RiggingReplies: 22Last Post: 07-31-2013, 09:57 PM
