Results 1 to 15 of 34
Thread: Swapout
11-12-2019, 02:15 PM #16000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
Swapout
Will a late '90's promax powerhead bolt onto a 2.4 mid without too much trouble. If it fit's would there be any real drawback of doing such a swap ?
11-12-2019, 04:06 PM #2
Everyone says dont run a 2.5 on 2.4 adapter plates buttt....
I did just that. installed a 2.5 on a 2.4 mid with 2.4 adapter plates and got little over 50hrs on it. lots of wot runs. Perfect water pressure great cooling , no issues for me. Just make sure u use the 2.4 gaskets. u will run hot with 2.5 gaskets. Mite have to trim exhaust dump holes to make em match
11-12-2019, 04:08 PM #36000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
11-12-2019, 04:14 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
11-12-2019, 04:33 PM #56000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
11-12-2019, 04:37 PM #66000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
11-12-2019, 04:39 PM #7
Promax make 2.5 and 3.0. U got 225 or a 300?
A 3.0 will not swapLast edited by Merc 2.5; 11-12-2019 at 05:42 PM.
tux974 liked this post
11-12-2019, 05:44 PM #86000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
11-12-2019, 05:48 PM #9
Ya the 3.0 promax is one of it's own. the 2.5 (200,225) different story. more can b swapped around
Other words anything over 225 pm is a 3.0
11-12-2019, 06:00 PM #106000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
OK, thanks.
11-12-2019, 07:41 PM #11
11-12-2019, 08:39 PM #12
So you cant run any 2.5 on 2.4 200 adap plates? 2 piece ?
I have one aet up just like that with 0 issues ever so far. Now I no u know exactly what ur doin also. Not being disrespectful at all. With that said. Reason I set mine up like this is because a builder here (well known) has set up many with no issues and it's the parts I had and everything has came out perfect. but everyone says cant b done. So I'm still kinda stumped by this. I do know cant mix the plates or gaskets again I am talking bout 2.4 200 with 2.5 200 poweheadLast edited by Merc 2.5; 11-12-2019 at 08:53 PM.
11-12-2019, 08:59 PM #13
I looked at using the 2.4 plate when I did my 2.5 clamshell swap but I couldn't find a reason not to use the 2.5 plate since I had it...
11-12-2019, 09:05 PM #14
Ya I tried finding 2.5 plates but ended up no so easy come by and was told bout this , so I went with it. Truth b told I didnt no if it would work or not. I was goin on his experiences and word. But it worked flawlessly still workin great. I'm not tryin down grade or start chit in any way. Just conversation
11-13-2019, 04:52 AM #15
I've run justa 'bout ever combination possible with 2.0's, 2.4's and 2.5's.. always use metal infused ph gaskets that fit tha "block" exhaust.. did tha "grindin' ta match exhaust on some and some not.. couldn't tell any difference... never a problem.. one piece and two piece present they're own problems with tha coolin' differences... jmo
