Results 1 to 7 of 7
    May 2015
    Winchester
    Mercury 260 block weld question
    A friend of mine when and looked at a 260 powerhead today and he noticed there was a dime sized weld on each cylinder close to where the cylinder meets crankcase was just curious what that might be ?thanks
    Apr 2016
    Victoria bc canada
    Most likely started life as 245 carb engine (same block) and someone has removed the bleed fittings required for a carb set up and has welded them.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
    May 2015
    Winchester
    Ok thanks....do you see any issues that could cause leak down and compression on engine are great
    Nov 2002
    St Leonard Md
    Post a pic. If it's a 245 there will be a kk block stamped on the side. 260 blocks have an LL or PP on the side.
    Probably has some porting done on the sides of the rod slots. They are pretty thin at that point and its not uncommon to see welds or epoxy there
    May 2015
    Winchester
    Thanks fellas I’ll try to get a picture of it and post it
    shreveport,la
    This right here
    Erik Kiser
  1. 2.5L Block Weld
    By bigshrimpin in forum Technical Discussion
    Last Post: 11-09-2015, 10:33 AM
  2. recomendations on who can weld a big hole in a merc 2.5 block
    By 88VTRocket in forum Technical Discussion
    Last Post: 05-19-2014, 06:09 PM
  3. jb weld on block
    By YELLOWSS in forum Technical Discussion
    Last Post: 10-15-2004, 04:19 PM
  4. Help!!-How to remove a steel sleeve to weld block
    By Valeroman in forum Technical Discussion
    Last Post: 04-07-2003, 11:59 AM
  5. CRACKED BLOCK!!! Should I weld?
    By pirogue in forum Technical Discussion
    Last Post: 10-24-2002, 10:47 PM
