Results 1 to 12 of 12
    Nov 2019
    Dunnellon FL
    250 xs lanier custom
    Recently purchased a lanier custom with a gold block 250 xs and what appears to be a 26 pitch four blade lightning et best I can tell. It has a torque master 1.75, My question is I am only able to turn this prop at 5600 rpm and the motor is rated at 6300 rpm . Does this seem right?
    compression is good and everything else checks out good on computer and gauges
    any help would be appreciated thanks
    Nov 2019
    Dunnellon FL
    Nov 2019
    Dunnellon FL
    Sep 2017
    ontario
    I am uncertain what weight a Lanier is and where your prop shaft is set . The 4 blade is not a lightning - i believe 3 blade only . Possibly a pro max . But that motor would turn a 26 well past 5600 . You best take a close look at it and discern what it is and know then what pitch it is and be somewhat better able to understand the low rpm . Your lugging it I believe . Torquemasyer lower I think . They are a nice motor , it' a v hull correct . Prop ID would be a good bit to know and maybe a bit tall for the hull . Hope this helps
    Sep 2017
    Ashland city tn
    Prop looks similar to a eagle 4 Ron hill prop I think. (Not 100%)positive on that tho. Prob has a stamp on inside of prop? A 26 4blade kinda like a 28 3 blade as in rpm wise. Depending on Weight of the boat is what rpm u will get ,and how high propshaft is runnin also. If u have that prop buried u wont see the rpm u should. it's made to b surfaced so the mota can spin up
    Nov 2019
    Dunnellon FL
    Quote Originally Posted by kellytheaker View Post
    Nov 2019
    Dunnellon FL
    It is a cat hull and I have a hydraulic jack plateClick image for larger version.
    Sep 2017
    Ashland city tn
    Raise it up 1/4in at a time till u start loose water pressure then drop it 1/4in. Looks to deep. but I've never ran a tunnel. it will prob handle better to when raised
    That prop is a Drag 4. The boat will run best with a 4 blade thru hub "hydromotive, pro max, modified Bravo, DeWald or Hering" to help provide total lift. The tube or barrel of the propeller helps a lot in the case of a heavy LCB "it acts as a gear case extension to ride up on" lifting the transom and packed air will lift the bow. You can't expect a low hp motor to push a heavy rig to its potential (that boat needs a 450).
    JPEROG, that TQ case isn't really a great case to surface is it?
    I forget that they make those cases LOL...
    Apr 2018
    Lake Placid, FL
    Call 954-650-9515, for Troy Lanier.
  1. The 2019 Lanier Custom Boats 28' Offshore!
    By JLanier571 in forum General Boating Discussion
    Last Post: 12-09-2018, 01:59 PM
  2. Lanier Custom Boat
    By CSD23 in forum Hulls Wanted
    Last Post: 06-06-2014, 04:00 PM
  3. 0 to 104 with 27 trophy(Lanier Custom)
    By scawd the dog in forum General Boating Discussion
    Last Post: 12-04-2008, 08:42 PM
  4. Lanier Custom Hooked up
    Last Post: 11-23-2008, 11:25 PM
