Results 1 to 8 of 8
Thread: Steering issue
    Apr 2011
    Western NC
    Steering issue
    I have a issue with my steering that has me perplexed.
    When I run straight I have to constantly keep turning the wheel left. It's a slow turn to the right, but it wont stay straight.
    Its an unbalanced Latham side ram with a Capilano 1275.
    Don't know if I should have the ram checked for leakage or possibly the lock valves in the helm are leaking.
    Dont think its air because the outboard is solid when I try to turn it by hand out back.
    Also the outboard turns on its own after towing for a while. Shouldn't it stay where I leave it?
    Latham states that an unbalanced ram cannot be run with a Capilano but it works. Just more effort in one direction.
    I don't believe this unbalance is my issue.
    Any Ideas?
    Apr 2017
    Holland,MI
    Sounds like you have some leaking in the ram. Seals go bad eventually but are easy to replace.
  3. Likes tux974 liked this post
    Apr 2011
    Western NC
    Iv'e been talking to Latham about this and they stated it must be either the ram or the Capilano helm pump.
    Latham rams rarely leak like this according to them.
    The helm would have to exceed 1000psi before the relief opens.
    I guess I will start with the ram.
    Thank you for your response.
    1998 22' Progression 300XS
    1988 15' Boston Whaler Johnson 70
    Mar 2009
    Port Saint Lucie
    Not to get the subject off the steering, but won't a boat that's in, let's call it perfect water, no wind or current perfectly flat, always turn slowly to the right due to the rotation of the propeller?
    Apr 2011
    Western NC
    Quote Originally Posted by Gorilla0178 View Post
    The driver will unknowingly compensate for this with a slight left offset. But you shouldn't have to constantly keep rotating the wheel left to keep the boat straight like in my case.
    Quote Originally Posted by Steve G View Post
    Obviously, Latham knows what they're doing... where do you think the excess hydraulic fluid is going when you turn the "hard" way? I'm surprised you haven't blown a hydraulic line off and crashed yet.
    Nov 2003
    Portsmouth VA
    Do you have a reservalve in the system? The fluid level changes when running one unbalanced cylinder and has to have a place to relieve to.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  9. #8
    Apr 2011
    Western NC
    The steering turns lock to lock without issue. There is a reservoir to handle the extra fluid in one direction due to the imbalance.
  1. Sea star steering issue
    By PGJ475 in forum Technical Discussion
    Last Post: 06-22-2016, 05:09 PM
  2. Steering issue
    By groundloop in forum Technical Discussion
    Last Post: 09-28-2014, 07:17 PM
  3. steering issue
    By 98xb2003 in forum Technical Discussion
    Last Post: 11-20-2011, 01:26 PM
  4. help!!! hyd steering issue!!!!
    By YELLOWSS in forum Technical Discussion
    Last Post: 08-13-2008, 10:36 AM
  5. Teleflex steering issue
    By markm in forum Technical Discussion
    Last Post: 08-07-2005, 02:44 PM
