Results 1 to 14 of 14
11-10-2019, 02:03 PM #15000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Solas Scorpion 24P with Rubex 19 spline hub kit
Mint 10 /10. Solas Scorpion part#: 9651-151-24, with 19 spline Rubex fat shaft hub kit installed. Ran for 15 minutes. Purchased for a new boat / engine but only turned 6000 rpm at 71 mph (too low). Reduced to $300 with hub. Will sell without a hub kit for $250. A Mercury Flo Torque hub kit will also fit.
01-12-2020, 05:50 PM #2Junior Member
- Jul 2007
Is this still available. I want to run this on 200 mercury with a stock lower. Don't think I need this hub.
01-12-2020, 06:20 PM #35000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Yes I still have it. I can sell it without the 19 spline hub and it will accept either a Mercury Flo-Torque hub or the Solas equivalent.
01-13-2020, 08:51 AM #4Junior Member
- Jul 2007
Doing a ton of research on this prop, thinking this is alittle tall for my hydrostream bowrider carrying a large load. Thinking probably a 22p.
01-14-2020, 04:58 PM #55000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
No problem, thanks for checking. To give you some idea, I could turn a 24P Bravo FS to 6200, a 24P Blaster into the rev limiter (6450) and the 24P Scorpion to 6000 rpm, perhaps 6150 rpm if I would have raised the Jackplate higher.
04-13-2020, 11:27 PM #6Junior Member
- May 2013
- Owasso, OK
- 17
PM sent
04-14-2020, 11:00 AM #75000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
On the same day I turned a stock 26P Bravo 1 to 5800 rpm with 13.4% slip. Then a 24 Bravo FS to 6200 rpm with 8.7% slip and the 24P Scorpion to 6000 rpm with 9.75% slip. A 26P Bravo is really 25.3P and a 24 is really 23.4P. Based on that and on my boat and engine, I turned the 3 blade 24P Scorpion 200 rpm higher than a 4 blade 25.3P (actual pitch) Bravo 1. I think I could have raised the Scorpion a bit higher but I ran all props at the same jack plate height. I also ran a 24P Blaster (almost 25% slip) and a 5 blade 23P Hill Marine the same day. Many people say 2" of pitch stiff for the Scorpion but on my boat it turned 200 rpm higher than than a 25.3 Bravo 1 (advertised 26P) but we all now Bravo props run shy of the stamped pitch. What do your turn the 25P Tempest at? Do you need a bit more or a bit less rpm?
04-14-2020, 10:32 PM #85000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Hi, I sent you a reply but it was not a PM but underneath your post that said PM sent. I included the rpm's I turned with the Scorpion vs other props
04-29-2020, 07:50 PM #96000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 427
- 63
- 433
- 450
05-11-2020, 08:44 PM #10
Is this still available?
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
05-11-2020, 10:42 PM #115000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Yes I still have the brand new 24P Scorpion (minus 10 minutes of run time for testing)
05-20-2020, 07:34 PM #12Junior Member
- Oct 2017
- Central Wisconsin
is this still available?
05-20-2020, 10:58 PM #135000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
05-21-2020, 10:21 PM #145000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
SOLD, SOLD, SOLD. Prop has been shipped to its new owner.
WTB Solas / Rubex S3 Scorpion in 23p
By Grant Conklin in forum Propellers WantedReplies: 23Last Post: 08-30-2020, 03:31 AM -
WTB Solas Scorpion 25
By Wolfjr in forum Propellers WantedReplies: 0Last Post: 02-10-2019, 07:23 PM -
WTB Solas Scorpion 28
By Finman in forum Propellers WantedReplies: 0Last Post: 11-03-2017, 03:48 AM -
24" Solas Rubex L4 -- Bravo I Copy
By lance in forum PropellersReplies: 1Last Post: 02-28-2017, 10:38 AM -
Solas rubex l4 prop
By WillySteve in forum General Boating DiscussionReplies: 1Last Post: 08-14-2016, 06:41 PM
