Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
    Jul 2005
    AZ
    Raising/lowering trailer w bad back
    Nothing new.. but didn't buy it just a bolt,cotter pin and few tools...
    Did this many years ago on trailers and now with back screwed up I actually use it... Always thought how damn lazy if you can't raise and lower it by hand, you are being a... well
    But yes saves my back so..
    Is it smart or lazy..lol
    All the way in 10 seconds ..one way
    https://photos.app.goo.gl/QgR74QvwctfH5r7B9
    Michael
    '84 Checkmate Convincor
    Sep 2017
    Ashland city tn
    Seems me drill mite not b strong enuff to raise it but idk. seems like decent idea if it raises it just as gud
    Jul 2005
    AZ
    Quote Originally Posted by Merc 2.5 View Post
    Drill raises it just as fast no problem...
    1/2" 20 volt variable speed drill ..
    Have raised and lowered it plenty even dying battery on low speed will lift it no problem
  4. Likes Merc 2.5 liked this post
    Sep 2017
    Ashland city tn
    Ya I was thinkin drill instead driver but ya the driver alot stronger and makes good sense
    Nov 2018
    New Baltimore Michigan
    That seems like a good idea,or you could buy an electric jack for a R.V. But they cost a couple hundred bucks and you need a good hot line from a battery or a vehicle. On the whole I think your design is fast and easy.
  7. Likes noli liked this post
    Jul 2005
    AZ
    Quote Originally Posted by Tin Man 2 View Post
    Yea Didn't cost me anything and just need to have the drill and battery and battery only take 15 minutes for full Charge or even 4 minutes is enough to use it..
    And wanted it like that so I still had the handle just in case.
    Yea The electric ones aren't cheap and don't have a handle.
    And only takes 1/2 hour not even that long if I was paying attention and not going back and forth .. lol
    Central, PA
    Clever idea, anything to save the back!
    mrichartz, I think you're onto sth here!
    if you can design a tongue jack that is powered by 1/2" drive battery operated hand-held device would be an awesome solution, even to those with no back problem
    Think about it, the unit can be charged inside the truck while driving or inside the house before going out
    how about the winch? today's hand-held batteries are very powerful. Use the same device to drive the mechanical winch. With small enough gears, even 27 foot boats can be winched with a hand-held device.
    wow, I would delete this thread and start getting someone to design this device tonight!
  12. Likes Glasstream15 liked this post
    ingenious -- as defined by the dictionary
    (adj.) clever, original, inventive
  14. Likes mrichartz liked this post
    Jul 2005
    AZ
    Quote Originally Posted by noli View Post
    Actually am working on something to work on the winch too using a 1/2 drill but it can be mount on the trailer too and just need to take battery out to charge it and have a winch cover over it so weather is fine
  16. Likes noli liked this post
    Jul 2005
    AZ
    It's already designed I can modify pretty much every Jack I've seen to work with the drill..
    But the winch on the other hand once/if I can get that done that should be sellable easy
  18. Likes noli liked this post
  19. #13
    wow, I can't believe this is all unraveling right in front of our eyes
    my leaf blower is all electric battery operated
    my weed cutter is electric battery operated,
    I'm also ready to pull the trigger on a batter operated snow blower cause I cn never get my dang engine running in the winter!
    todays batteries are so powerful
    I would also throw in there a battery operated wheel-dolly for maneuvering into tight spaces. Yes there's one out there already, but it costs thousands, if we can use the same battery (or three) to drive the wheel-dolly, would be so awesome!
  20. #14
    Jul 2005
    AZ
    Actually trailer dolly less than $200 not sure how good but..
    https://rover.ebay.com/rover/0/0/0?m...2F112659436580
    Actually the motor off that, forward and reverse for winch but with the 80v battery's they have now would be good
    Working on a couple different setups for the winch
    As powerful and compact as possible
  21. Likes noli, Glasstream15 liked this post
  22. #15
    Always a easier way everything! Damn, 60 years ago my Dad chucked that POS lousy recoil lawnmower and a socket on the flywheel and a 110 drill? And he was 50 (1950) when I was born! Learned a LOT "how to do when getting old"! Use the brain not the brawn !
  23. Likes mrichartz liked this post
  1. Frostman's Skater Goes Back On The Trailer
    By action17 in forum General Boating Discussion
    Last Post: 03-05-2012, 08:37 AM
  2. LOWERING a 4WD Ranger?
    By WATERWINGS in forum Tow Vehicles and Trailers
    Last Post: 08-11-2008, 02:00 PM
  3. Lowering compression.....
    By speedaholic in forum Technical Discussion
    Last Post: 07-13-2007, 12:59 AM
  4. Lowering engine = loosing speed?
    By bigboy in forum Props, Setup, and Rigging
    Last Post: 05-16-2007, 06:08 AM
  5. Back Issue of Trailer Boats with stoker project
    By rebible in forum General Boating Discussion
    Last Post: 07-06-2006, 09:18 AM
