Results 1 to 3 of 3
    Aug 2005
    West Allis,Wisconsin
    Timing Instructions
    Does anyone have timing instructions for procedure on how to time all 6 cyls. and mark the flywheel for 225 PM?
    You will need to own or have access to a TDC indicator. Jay Smith sells a Pretty nice one. Remove all 6 spark plugs. Incert the TDC indicator in #1. Rotate flywheel clockwise till TDC is reached. Then Rotate flywheel counter clock wise .150 ths. Thats 25 degs or .006 ths per degree (.150/.006 = 25 deg). If you want to time at say 23 degs mark flywheel at .138 ths). Mark flywheel at timing pointer. Repeat on remaining 5 cylinders. Hook up a Timing light. With the timing arm locked all the way back to Full advance. Spin engine over timing each cylinder to determine which of the 6 cylinders is the most advanced. Its not always #1 could be any one of them. Time to desired Timing on the Advanced cylinder. If adjustment is needed loosen the 7/16 jam nut locking the Phillips head adjustment screw. Adjust by screwing in or out till desired timing is reached. Lock jam nut.
  3. Thanks bbezok thanked for this post
    Aug 2005
    Quote Originally Posted by HStream1 View Post
    Thanks for the info!
  1. Mercury Tech: Single Ram Repair Kit Instructions
    By chubsta in forum Technical Discussion
    Last Post: 07-09-2010, 08:04 PM
  2. Seastar pro steering instructions???
    By Swamp boy in forum General Boating Discussion
    Last Post: 09-01-2008, 12:10 PM
  3. Oil changing instructions. FUNNY!!!
    By aircraftman in forum The Scream And Fly Lounge
    Last Post: 07-18-2003, 05:45 PM
  4. Leakdown instructions for 2 strokes
    By Hank W in forum Technical Discussion
    Last Post: 08-13-2002, 08:14 AM
