Results 16 to 30 of 45
    Sep 2017
    Ashland city tn
    Have u tried to ohm stator yet or trigger?? Any parts layin round (electrical)
  2. #17
    May 2016
    Long Beach, CA
    If you still have it hooked up .... the Idle stableizer/////advance box.
    no stabilizer.. Ill dbl check the coil grounds - i got good dva on the terminals and re-screwed each terminal to/from coils/packs to make good connections -
  3. #18
    May 2016
    Long Beach, CA
    Quote Originally Posted by Merc 2.5 View Post
    All ohms show fine numbers on stator and trigger - dva also good!! only the packs had a 7000 bias difference - one was in spec @ 14k, the other was 21k! Replaced with a pair from CDI- no change..
    The replacement stator was about 1/16th of an inch thicker - could this cause issues? its one of the 3 stators listed for my motor, and theres a picture that says "lamination thickness" - i guess they had various thicknesses.. new stator seems to run wierd.. different sound -
    No parts lying around unfortunately -
  4. #19
    TX......somewhere?
    run it in tha "dark of night" without tha cowls...………..
  5. Likes KIRCHNER, TNRoostertail, Dave Strong liked this post
  6. #20
    Dec 2001
    A different sound.....happened to me once.... the motor had the yellow tag missing on the wires and the stator,coils and trigger were not paired and messed the timeng up. My brother had a bad F/w......drove him crazy.
  7. #21
    May 2016
    Long Beach, CA
    Sounds about right! Now where do I find a matching flywheel!
  8. #22
    May 2016
    Long Beach, CA
    Anyone in Socal near Long beach have a 200 flywheel I can test with? pm me plz :/
  9. #23
    Feb 2011
    HUDSON, FLORIDA
    Doubt that gives intermittent spark. Either all or none power wise. Just went thru that on another thread
    yes indeed, KEY SWITCH.. dont ask...
  10. #24
    Feb 2011
    HUDSON, FLORIDA
    solved many electrical ghosts for me.
  11. #25
    May 2016
    Long Beach, CA
    i did test with harness disconnected and same symptoms - new plug wires, but for peace of mind ill run her in the dark this evening..
  12. #26
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Fstarockr View Post
    Well reason I asked. Is lots times things get tested and "pass" but if u swap part issue goes away. Has happened alot. Not saying its ur prob but nice to have a ex part. I have few parts if u can narrow it down
  13. #27
    Feb 2014
    Missouri
    Check voltage to the scr. Since we seam to be giving the switch boxes a pass.
    The new parts might not be providing enough voltage to fire the switch and woltage will drop or does it go up on that as rpm increase dropping more cylinders.
    The other issue that would happen is weird timing from the capacitor charge rate.
    Tracing the voltage on the scr in the box is about as weird as it gets, and normally for a bias or stabilizing check. But it can mess with non stable units with either the scr blown or not enough voltage to trigger the switch. It’s pretty rare
    you can also tap the greens to see if voltage is even sent to the coil. I forget the old setting was it dwell time or such, it tested coil charge time and would throw it back to a bad capacitor in the switch box if it was low or something. Don’t see the test much these days.
  14. #28
    May 2016
    Long Beach, CA
    motv - all v at coils almost identical to terminals at packs- volts increase steady as rpms increase..
    tried it in the dark last night - no sparks. im going to maybe put it on the water and see how the power is
  15. #29
    How is the stator oriented..and your not letting the timing light pick up sag near the other plug wires?
  16. Thanks Fstarockr thanked for this post
    Likes gmacrae liked this post
  17. #30
    new york babylon
    I had a flywheel drive me crazy changed everything spark scatter was all over the place changed flywheel ran great for 7 years ex test
  18. Thanks Fstarockr thanked for this post
  1. 'rude 150 intermittent cut/miss
    By Looper in forum Technical Discussion
    Last Post: 08-27-2001, 08:56 AM
