Results 1 to 3 of 3
Thread: HPDI injector gasket removal
11-08-2019, 08:27 PM #1Junior Member
- Nov 2014
- United States
- 28
Hi guys, I've got an HPDI on the bench that had an injector gasket tear after pulling the fuel rail off. Tried being gentle with it and can't get it off so I figured one of you might know a little more about how to go about it.
https://www.offshoremarineparts.com/...xoCYNgQAvD_BwE this is the gasket I'm referring to
11-08-2019, 11:19 PM #2
Did it tear or did the two just separate? If tore, are you having problems getting it off the injector or from in hole in head? If it’s stuck to injector sealing surface, try carefully using a razor blade and slip in between gasket and injector surface and walk around until it’s unstuck.
11-09-2019, 12:33 AM #3
Quit being an internet homo, peel the gasket off and be a ****ing man.
02 Vmax HPDI blown head gasket questions
By Jamie Nichols in forum Technical DiscussionReplies: 6Last Post: 06-21-2018, 08:21 PM -
Yamaha HPDI 150 fuel injector filters?
By Waterdigger in forum Technical DiscussionReplies: 2Last Post: 01-11-2015, 11:09 AM -
No injector pulse #2 Yami HPDI
By davepnola in forum Technical DiscussionReplies: 0Last Post: 07-01-2009, 12:13 AM -
injector removal, '98 3.0 225 ???
By Instigator in forum Technical DiscussionReplies: 3Last Post: 10-29-2007, 05:22 PM -
injector removal
By OBSESSION in forum Technical DiscussionReplies: 8Last Post: 01-29-2003, 11:24 AM
